It makes no sense
No sense, NONSENSE I tells ya...
But srs why not come over to this whore town, talk crap (for free mind you) get more people interested and be easier to access... Some people
I see your Wife getting around in the beatle nearly every morning on my way to work now, She had your skyline the other day.
You could always come visit me if you miss me that much.
So...My supposedly top notch custom heavy duty clutch that is just over a year old (sub 5000k's) is already nearly worn out... took it for a drive today and noticed that my clutch engages half way up the pedal.
I will be adding that to the list of stuff to replace in July.
Yup on her way to work in Clonarf. She had my car for a few days, as hers was getting a new carby and tuning.
I have been meaning to come and say g'day
And how is the upper north Brissy?
same old same old
Same as normal, needs more mountain runs.
this
Thats lame, What brand is it? and i assume you have checked clutch fluid lvls? not that its leaking everywhere.
Drop me a message or a call and come up for a beer man check out the new digs.
It was custom built by RPM, I don't think it is a fluid issue.
Edited by RandomHero83
its not...... Its pretty much purchase by the Drum. Sucrogen E85 is what it will be running on. Long story short, getting a Haltech sensor installed in fuel line which can sense the blend of fuel so i can run either E85 or 98 pump. Even a mix of both, then the ecu will adjust the tune accordingly
That's pretty cool and probably more manageable as well. How much of a power difference is there between the E85 & 98 for you?
if i get a 15% power increase ill be happy.
What Power is it running now and what have you done with it since last I viewed the forum?
makes 350hp, havent changed much.
Still Internally gated GT3076,low mounted
ViPEC ecu
740cc injectors,
4" Cold Air intake
Upgraded cams
APR Headstuds & Metal Head Gasket
Heads been rebuilt
Full 3" exhaust
Probably a few more things i cant thing of at 545am..
Ill be happy if i can break through the 400hp mark
ViPEC ecu
740cc injectors,
4" Cold Air intake
Upgraded cams
Heads been rebuilt
Full 3" exhaust
Yeah in July mine is going to a new shop to break the 400 mark, I'd say it will be back in for a new brand name clutch and a metal head gasket not long after if not during
Get video footage of the Kaboom?
I Like it in here......Whoretown goes far to fast, It's been 3 pages since my last post and from what i can tell its all about how many posts we have...lol. Bunch of Nerds over there :whistling:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
