Don't we all? But you won't get the with the abomination.
:( no, only slurries with no brains... I like brainy females.
In saying that I had Mary sit in it a while back and all she had to say was "it shakes" as she sat in the seat grinning.
I have a feeling it was making her "happy" lol
Pffft, if given the choice slurries would sooner jump in my car then the rest of the drab boring skylines in the club I mean marron/grey/white boring!
.... The scary part is I think the old man has the more out there colour scheme out of everyone
Who wants a dumb bimbo! Us sexy smart bitches are sooo much cooler
Bahaha. Cars that 'shake' are always lots of fun. A friend of told me thats the only reason she used to play Play Station, she'd just hold the remote down low and run into things.
Who da fark is Mary? Does she have a little lamb?
So it shakes like someone having a sezure? Sounds about right :P
Mary is a f**king long story that messes up my perception of reality and ability to form coherent sentences... Ask luke he knows
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
