Car is back, Serviced and tuned. Making 341hp with more to come, I ran out of Dyno money because my radiator decided that it didn't need a top pipe connector.
Feels really responsive under power and feels nice and granny spec when cruising around town in higher gears. Not running rich now and when you hit the hammer she really goes.
A bit more work will pull another 30 - 40hp (to tune the duty on the ebc to keep the boost up at the end of gears) but I am leaning towards going to a GT35R.
Really happy with Richard at All Star Tuning in Brendale.
Car broke down this morning on the way to work. Lost power during gear change and wouldnt kick over again. Hoping its just a battery related issue and i can jump start it. Unfortunately due to having to get to work i had to ditch her on the ride of the road, walk back the 2kms to home and grab my daily
No that feel, my bluebird decided it wanted to break this morning as well the bar between the throttle and the butterfly valve for the air flow came loose, zip-tied back together for a temp fix
That sucks man. Ive never HAD to leave my car sitting on the side of the road for long. Hope its something simple
I have, when my fuel pump shit it self, oh and when I broke two wheel studs, oh and when I ran out of fuel :)
After coming back to the car and not being half asleep and 4am in the morning.. I'm feeling its fuel pump. Kicks over fine, can't hear the fuel pump when I turn the car on.. Pumps brand new so hopefully it's an easy fix
So the part that's broken on the bluebird I'm gonna have to get from Nissan themselves anyone know where on ecan go to get a engine bay break down image or now the name of the linkage that goes from the end of the throttle cable to the butterfly valve?
Through nissan for some reason I doubt it. Is there a specific branch of nissan to ring for spare parts or should any branch be able to help? Might even price up a new oil bypass pipe for the skyline.
Edit: did a little interwebs sleuthing and yeah probably under $10.
Metro Nissan @ Windsor and Village Nissan @ Petrie I have found both to be very helpful, as long as you can give them the part number.
Their willingness to look up part numbers for imports though will depend on who you speak too, their mood, the time of day, alignment of the planets, etc.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
