I nominate RandomHero83 for the position of executive director of memberships
What would be a serious estimation of time involved in that job? I would need to discuss anything with the wife lest I be struck dead by way of frying pan to the head. I would like to participate more in Club activities and such but need to work that around work, wife and kids.
That would be a considerable amount of time, Not much of an issue during the winter months but in summer I work up to 100hr weeks which would negatively Impact on my availability and thus on the club.
Perhaps next year I will be in a suitable position to be nominated and actually serve as an Exec.
The club is certainly worth the Investment of time and I look forward to freeing up some time so that I can be a more active member.
^This is why we're all so strung out. :)
Bear in mind, I said at least. When you're trying to rebuild and rejuvenate, it does take quite a heavy toll. I'm on the phone to Scott at least 2-3 times a week for at least 20-30 minutes each time. Then implementing what we've discussed and waiting on feedback. Then moving to the next stage or rectifying any issues and waiting for approval again. It's quite tedious but the fact that it;s 5-10 minutes here and there doesn't make it feel like a lot. But when you look back at your week and realise that you've put in 4 hours for dinner and then all the other bits and peices, it adds up quickly. Very quickly.
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
