That's an old battery. Also, really cheap price.
If I was around, I would have grabbed you.
Cheers Tony, Yeah i was really happy with the Price
Zeke, Your car will run it without issue if anything it will run better than it ever has.
Im going to fill a tank and try it.
That's like saying you are a beer drinker going out on the town and a mate says try a bourbon. Nah bro my liver will implode!!!
I will cry if my car breaks.........
Let me know if your car implodes. Mine is a 94 so by the looks of your display pic you have a series 1 as well.
still got 2/3 v-power Zeke, so just be a top up, but will def go a full tank just to see if there is any diff. I will try nearly anything once....except guys
You want to try guys...
Not that there's anything wrong with that..
coils and plugs usually, It is really common, What gap are your plugs?
dunno wat gap is but east coast customs said it wasnt the plugs and would more than likely be a coil. BTW p100 down the highway at 110kph, boost sits at -17/-18 psi cruising, usually its -15psi ..... should say vacuum not boost.
if this ^^^ shouldnt be happening maybe my gauge is kaputz
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
