That's an old battery. Also, really cheap price.
If I was around, I would have grabbed you.
Cheers Tony, Yeah i was really happy with the Price
Zeke, Your car will run it without issue if anything it will run better than it ever has.
Im going to fill a tank and try it.
That's like saying you are a beer drinker going out on the town and a mate says try a bourbon. Nah bro my liver will implode!!!
I will cry if my car breaks.........
Let me know if your car implodes. Mine is a 94 so by the looks of your display pic you have a series 1 as well.
still got 2/3 v-power Zeke, so just be a top up, but will def go a full tank just to see if there is any diff. I will try nearly anything once....except guys
You want to try guys...
Not that there's anything wrong with that..
coils and plugs usually, It is really common, What gap are your plugs?
dunno wat gap is but east coast customs said it wasnt the plugs and would more than likely be a coil. BTW p100 down the highway at 110kph, boost sits at -17/-18 psi cruising, usually its -15psi ..... should say vacuum not boost.
if this ^^^ shouldnt be happening maybe my gauge is kaputz
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
