Off the subject of sore backs and pain killers does anyone know of a aluminium fabricator/welder in morayfield/caboolture area I'm after a sump extension fitted any help would be great.
Sorry mate no idea, a couple other guys live in that area so hopefully they know of one.
Sorry buddy, no idea myself. Pete over at RPM might be able to, or lead you in the right direction.
Oh shit. I'll be at yours in 20 with a case of beer and rebar.
Need to get you drunk and then bet all the nick out of you.
I'm getting the sudden urge to put an LS1 in my skyline...
  • Like 1
Morning north siders.
Moaning. It's one of those days. Machine was fine and randomly started playing up trying to fix more stuff goes wrong and now beyond my knowledge of the machine to fix. Someone's getting a phond call on their first day of holidays :)
Sup pingers, long time no stir.
Hows the northern side faring?
Ive been pretty busy with work and babies lately as usual, dont get much time to play anymore! :(
No new mods, just in the process of respraying the wheels.
Pce
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
