Evening Bodo! Just got back from the sunny...some idiot crashed their BMW and closed the highway for 30 mins.
<br /><br />You were up the sunny and didn't even come visit me you lazy fark.
I was up there for 30 minutes last night to drop Connie's brother home, I have no desire to spend any more time than necessary up there lol.
<br /><br />:( I see how it is.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
