My parents got a Maltese about a month ago and called it Bella
Bella is a cats name not a dog lol
She politely requested that you both partake in the eating of a bag of Phallus's (is it Phali?)
What Scott said.
I tried to pitch Pugzilla to her but she said no.
Work is highly over rated. The boss has gone on holiday which leaves me in charge of Operations. Seems like i might actually have to do some work over the next two weeks
I'm taking on more of the operations side of the business now which is on top of my normal duties....
I've just moved to bribie from nz. Do you guys meet up at all?
I dont, not sure about the other guys up here. Where abouts on Bribie have you moved to? I work at PAcific Harbour Golf Club but im in Woorim regularly and live just off the island
that too, think i'll give it a miss though. As much as I really want to, and havent heard anything else. I don't wanna push it.
<br /><br />They didn't take your licence off you or twll you weren't allowed to drive.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
