Nearly 2 months on, but i finally have my speedo sender, arrived today and is installed and WORKING!!
hard to tell how much the power steering coming back has changed things, as i have different wheels, different steering wheel and HICAS removed.
atleast when i get it rego'd i'll be able to drive it around a bit and get some road tuning done.
  • Replies 184
Posted Images
  • 2 months later...
Spent a little time on this in the last 2 months, though not enough :(
Car is rego'd and running on the road!
took the car out for a few drives and was blowing IC hoses - easy fix with welding on some beads to the new alloy piping i made
Car is running better and better everytime i take it out. Fiddled with the tune and did some logging with the datalogit - ended up adding 4 degrees of timing in the off boost area with only 3 cells reporting 15 or 16 knock in the logs - just have a loose connection in the wideband setup that stops it working every now and then. probably something i did when i was hooking the PLX SM-AFR up to the datalogit unit.
Anyway, it feels much faster than my stocker 33 for normal road driving, as any boost really does send me over the speed limit lol - think i can get to about 3psi before im speeding haha
best thing - its so quiet!!! (well except the exhaust) - no rattles, no knocks just a little scrubbing on the stock rear guards over bumps, so a quick roll of the guards should sort that out.
Cheers Dave - chop chop :P
time to finished the interior for me though
Ah well I have already finished that part of mine.
BTW more coating to be done soon on a new strut brace. Friggen C/F bonnet won't shut with teh nismo one :(
that sucks dave :( i'll see if i can find any spare alloy to make a new centre for you.
Some pics of the new manifold im making from my fabrication thread - http://www.skylinesa...ds-fabrication/
  • 10 months later...
Cant believe how long its been already - hoping to get a bunch of stuff fitted for the cruise on the 30th - see how that goes
car needs some tunes, so a mount for the Amp needs to be fabricated asap.
Wow! Been ages........... i wanted to make that cruise but will depend on how the car is running with the issues.................
SO much positive feedback from your handy work ;)
nothing new, i havent had time to drive it since i got it home, jsut in and out of shed a few times lol
time for fresh fuel, new fuel surge tank, amp mount and some street tyres on another set of 350z rims i bought.
its been pretty crazy after moving into my new shop and expanding the services i provide into the domestic and commercial/industrial market.
but now i've had some time to get working on my own things again.
newly coated bronze 350z rims with some federal 595's for street duties
Then in prep of getting my 26/30 finished one day i figured ill spend on a known commodity of a 6boost manifold - designed for the 26/30 but with a 25/26 flange pattern so i can get it installed on the RB25 and only have limited changes to make when the motor is built and swapped over.
upgraded from the tial 38mm wastegate to the turbosmart 50mm item, the old setup had the gate hanging right down at the chassis rail via some adapters etc, never caused any issues but wasnt as neat as id like
got some time to perfect the surge tank design, my original fabricated one was around 4.5L and overkill.
new one is 2L and alot tighter to the car and will weigh less and is easier to replicate if anybody would want one.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
