Hi All,
I tried this in the NSW section, but not getting any replies :D
Currently importing a R32 GT-R and I want to get everything sorted well and truely before the car gets anywhere near Australia. Geoff from Prestige recommended the following companies to do the necessary modifications to comply with the ADRs (the price they quoted me is listed):
Southside Performance Imports: $1200 + blue slip + rego.
GM World (Auto Disposals): $2000 (inc blue slip) + rego.
Sydney Compliance Centre: $1500 (can't remember if it was inc/ex blue slip).
Has anyone had experience with those three companies? Was it good, bad, indifferent? Anyone who has used a different company, feel free to post the details plus any comments about them.
Thanks guys!
Lucien.
ive been told that anyone can do this. i mean anyone can install all necessary items such as flat drivers side mirrors, side intrusion bars etc... im currently looking for a compant to do this aswell. another cost invloved is tyres. im just making sure i get a set of cheap wheels before so i dont have to fork out the money for brank new tyres (im cheap)
I did all teh work myself except the side intution bars as they require buying a kit pulling the doors off and appart and welding in place. I have had dealings with SSPI and I found them to be very good to talk to and deal with. I refure you to the below contact:
Stirling,
Normally we would charge $1200 for all the work required:
Child Restraint Mounts (2) - Supply and fit
High Level Mount Stop light - Supply and fit
Drivers side mirror (flat) - Supply and fit (no longer required)
Unleaded Fuel Filler Restictor - Supply and fit (replaced with a ULP sticker)
Side Intrusion Bars - Supply and fit
Engineers Certificate (prove car meets ADR's)
But if you only need the Child Restraint mounts and intrusion bars we would
charge $600 for those as they are the most difficult jobs required.
You would also need an Engineers report to prove the car meets the ADR's,
these are normally between $500-$550, but we could do one for you for $400
if gotten as a package with Child Restraints and Intrusion bars.
Total of $1000.
Regards
Emanuel
22/3-11 Flora Street
Kirrawee, NSW, 2233
Ph: 02 95424280
Fax: 02 95424285
Mob: Emanuel 0417 029545
Mob: Chris 0416 223437
Email: [email protected]
Web: www.sspi.com.au
This was the best quote I recieved. I did not endup going for it as I pulled teh doors off and apart, Skyline Performance in Canberra are doing the intrusion bars as offered to do teh kit and welding for $450. Being they are in canberra it makes life much easier.
I would suggest going with SSPI if you are in sydney, that price for all the work and teh cert is great..
I might also ad that the other work is very simple cheep and you should do your self, how ever for $200 you could save your self all the effort ie: drive in drive out..
Hope this helped!
Stirlo_GTR: Thanks for that. SSPI certainly have given me the best quote so far. I may also consider doing most of the work myself since it doesn't seem difficult from what you are saying. Are you able to tell me where you sourced the parts?
Cheers,
Lucien.
Stirlo: Good work. I will also be giving SSPI a call.
Lwells: Got the news about the de-gassing laws? Geoff told me last night. My car will be delayed two weeks due to it im told
The only part you will need to buy and instal is the high mount stop light which I got from auto barn, most auto shops will carry them for about $20... thats all you need to do.. :D
The fuel restrictor is no longer required as it was only there to stop fools from putting deisel or leaded (what ever) fuel in an ULP car.. Deisel/ Leaded (what ever) is no longer available at any pump in aust, and hence you only need a sticker to say ULP only, SSPI can provide this..
Flat mirror is no longer required as of Jan 1st 2004.
This only leaves the child restraints/ intrution bars/ eng cert to do which I would suggest you get SSPI to do for you for $1000... and your all sweet for rego.
depends on condition normal ADR's apply ie would they pass normal rego? give them the pull 1o times test, if they grap no worrys 10 times and dont slip they'll be fine.. make sure there are no freys etc remember these are what saves your life so its important make sure they are in good order.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
