I've started looking into graphics cards and have been wondering whether to go a high end older card or a mid-range newer card.
One factor is the directx support. I had no idea what the difference was until I stumbled across this thread (yes, it's from 2009) that explains and shows the differences very well.
http://www.overclock...-vs-dx-9-a.html
I tried using the ol' search button but didn't find anything explaining the differences.
Here are some pics of the same scene, but under the different versions.
post-51176-0-50216500-1300341329_thumb.jpg You'll notice that the differences between DX9 and 10 are minimal with only better shading and light
post-51176-0-42146100-1300341362_thumb.jpg DX11 is like a whole different league; more 3Dness so to speak - the biggest change is the detail in the road.
I know it's an old subject and I'm a couple of years behind but I figured it's good to know the differences. DX11 is definitely the way to go.
Windows XP - DX9 ONLY
Windows Vista - DX10 (can be updated to DX11)
Windows 7 - DX11
https://www.sau.com.au/forums/topic/357762-directx-11-vs-dx10-vs-dx9/
i would go Dx11 no point going backwards
and something like ati 6870 1gb is pretty cheap nowadays
http://msy.com.au/product.jsp?productId=6837 $229
i can only find 1 Nvidia in a similar price range
http://msy.com.au/product.jsp?productId=7305 $277 GTX560
the 6870 is probably a higher binned 6850. So whilst it may work on most cards, there is potentially a portion that won't work after flashing it. I could be wrong though, cbf researching.
BTW that directx 11 shot seems to be showing off tesselation more than anything ;)
Well apparently that's what dx11 is all about. It's basically dx10 but with completely revamped tesselation properties.
I think instead of having multiple levels/layers of models, they have only two. Dx10 and earlier would have the lowest detailed model up close covered by the next level, covered again by another level and so on; therefore all levels are loaded for up close models even though we only see the last level/layer. Dx11 on the other hand will only load the highest detailed model close up until a certain distance and then change to the low detailed model.
6850 is same as a 6870, with minor diffs, but you reflash bios and it works 100%, out of the 30-40ish ppl i know on the overclocking forums, all their cards work fine :)
DO IT!!!
i for one, just bought the gtx570 which just kicks pure assssss!!!
Windows 7 - DX11
in dx11 that road is retarded, theres no way anyone could walk on that without twisting an ankle
[quote name=ClutchBurndout-:(' timestamp='1300745012' post='5724470]
Haha. Fk driving on it too. Stiff suspension + road like that = fkd spine; and forget it if your busting for a piss.
Hey guys,
I just installed a genuine copy of Windows 7 64-bit Home Premium.
I am not sure if my operating system is now running Direct X 11. How can I tell or where do I search in Windows 7 to find if it is?
My PC specs are as follows (if its of any importance) -
  • Intel Quad Core 3.2ghz
  • 4.0gb 1333mhz ram (yes I know that's sh!t, i'm upgrading to 12gb 2000mhz soon!)
  • Gigabyte 1gb graphics card (can't remember the exact model name, paid about $300 for it just over 12months ago)
  • Asus mother-board (once again can't remember specs etc)
My PC runs games such a COD: Black Cocks & Battlefield: Bad Company 2 one maximum graphics and runs both of them smooooooooth as silk, both in singleplayer & multiplayer. WoW runs perfectly smooth, you get the idea.
I'm pretty sure my graphics card is an ATI Radeon HD 4850.
It seems to perform very well, and when i had XP and the Catalyst Control Centre installed, i overclocked it and it still ran fine and didnt overheat etc
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
