I've started looking into graphics cards and have been wondering whether to go a high end older card or a mid-range newer card.
One factor is the directx support. I had no idea what the difference was until I stumbled across this thread (yes, it's from 2009) that explains and shows the differences very well.
http://www.overclock...-vs-dx-9-a.html
I tried using the ol' search button but didn't find anything explaining the differences.
Here are some pics of the same scene, but under the different versions.
post-51176-0-50216500-1300341329_thumb.jpg You'll notice that the differences between DX9 and 10 are minimal with only better shading and light
post-51176-0-42146100-1300341362_thumb.jpg DX11 is like a whole different league; more 3Dness so to speak - the biggest change is the detail in the road.
I know it's an old subject and I'm a couple of years behind but I figured it's good to know the differences. DX11 is definitely the way to go.
Windows XP - DX9 ONLY
Windows Vista - DX10 (can be updated to DX11)
Windows 7 - DX11
https://www.sau.com.au/forums/topic/357762-directx-11-vs-dx10-vs-dx9/
i would go Dx11 no point going backwards
and something like ati 6870 1gb is pretty cheap nowadays
http://msy.com.au/product.jsp?productId=6837 $229
i can only find 1 Nvidia in a similar price range
http://msy.com.au/product.jsp?productId=7305 $277 GTX560
the 6870 is probably a higher binned 6850. So whilst it may work on most cards, there is potentially a portion that won't work after flashing it. I could be wrong though, cbf researching.
BTW that directx 11 shot seems to be showing off tesselation more than anything ;)
Well apparently that's what dx11 is all about. It's basically dx10 but with completely revamped tesselation properties.
I think instead of having multiple levels/layers of models, they have only two. Dx10 and earlier would have the lowest detailed model up close covered by the next level, covered again by another level and so on; therefore all levels are loaded for up close models even though we only see the last level/layer. Dx11 on the other hand will only load the highest detailed model close up until a certain distance and then change to the low detailed model.
6850 is same as a 6870, with minor diffs, but you reflash bios and it works 100%, out of the 30-40ish ppl i know on the overclocking forums, all their cards work fine :)
DO IT!!!
i for one, just bought the gtx570 which just kicks pure assssss!!!
Windows 7 - DX11
in dx11 that road is retarded, theres no way anyone could walk on that without twisting an ankle
[quote name=ClutchBurndout-:(' timestamp='1300745012' post='5724470]
Haha. Fk driving on it too. Stiff suspension + road like that = fkd spine; and forget it if your busting for a piss.
Hey guys,
I just installed a genuine copy of Windows 7 64-bit Home Premium.
I am not sure if my operating system is now running Direct X 11. How can I tell or where do I search in Windows 7 to find if it is?
My PC specs are as follows (if its of any importance) -
  • Intel Quad Core 3.2ghz
  • 4.0gb 1333mhz ram (yes I know that's sh!t, i'm upgrading to 12gb 2000mhz soon!)
  • Gigabyte 1gb graphics card (can't remember the exact model name, paid about $300 for it just over 12months ago)
  • Asus mother-board (once again can't remember specs etc)
My PC runs games such a COD: Black Cocks & Battlefield: Bad Company 2 one maximum graphics and runs both of them smooooooooth as silk, both in singleplayer & multiplayer. WoW runs perfectly smooth, you get the idea.
I'm pretty sure my graphics card is an ATI Radeon HD 4850.
It seems to perform very well, and when i had XP and the Catalyst Control Centre installed, i overclocked it and it still ran fine and didnt overheat etc
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
