I have the following parts located southside Brisbane i would prefer pick up but will post at buyers expense.
All Prices are negotiable.
High flow r32 gtr turbo -$250
High flow r32 gtr turbo that requires rebuild - $100
Rb36 Cams - $250
Polished twin turbo distributor - $150
Rb26 twin turbo AFM - $50
Rb26 twin turbo AFM with broken flange(sure u can glue it back together) - $10
Water lines - $30
https://www.sau.com.au/forums/topic/357902-r32-gtr/
  • 3 weeks later...
  • 3 weeks later...
Hey mate was just wondering if you had any rear gtr Hubs that the driive shafts from the diff atttach to?
Rb36 Cams - $250
Water lines - $30
https://www.sau.com.au/forums/topic/357902-r32-gtr/#findComment-5815674
I HAVE THE FOLLOWING STILL FOR SALE
Rb36 Cams
Rb26 twin turbo AFM
Water lines
https://www.sau.com.au/forums/topic/357902-r32-gtr/#findComment-5829283
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
