Hi guys, I get my baby this week sometime, and I wanna know if i should save up $1000+ dollars for an aftermarket jap cat back, or get a custom cat back made... I am a bit concerned about the loudness of the jap ones, as i dont really want to attract the cops... Are they really that loud, or are there slightly quieter, even legal ones??
Cheers.
PS how much should I look to be spendin on a cat-back??
:bond:
https://www.sau.com.au/forums/topic/35811-custom-or-aftermarket-exhaust/
i would go custom cost less and does the same job and you can get them to sit higher under the car so they dont hit thing.......dont let some one tell you they not as good, and how hks ect. who spend millons on deveolment (ture) are better not ture.... if the guy doing it knows what he is doing it will be just as good...... i spent 1500 on mine and it makes the same kw as big name jobs
gizmo and nmcmahon83
are u going on the 12th cruise???
if not then u should be
need to get more coastal ppl involved in this club and its cruises......
and it would be a good chance for yallto c must swanky custom exhaust
which by the way was done at TM at tuggerah
which by the way is having a dyno day on the 20th
end rant
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
