I've been thinking about the best way to go for an RB25 upgrade for my R32. I don't want to be ripped off or dissappointed so I'm just wondering...
What's the best way to go with an RB25 upgrade and what should I be paying for one?
An estimate price for a stuffed engine that needs rebuilding would be great and maybe a price for a low km engine that can go straight i would be awesome.
James
just keep an eye on the for sale section, also call around the jap wreckers to see what they charge for a complete engine to give yourself something to reference to.
http://www.skylinesaustralia.com/forums/topic/358328-real-deal-rb25-setup/page__p__5725529__hl__rb25__fromsearch__1#entry5725529
http://www.skylinesa..._1#entry5725529
So his rebuilt, forged engine is going for $1700 and his rebuilt gearbox is going for $1500 and the only other things i'll need are a computer and loom.
Not too shabby. Just depends whether its worth it or not. If I can get my 32 to 300rwkw for roughly the same I won't bother aha.
You got a conversion in yours?
yea, mine has a rb25 with a gt3076. In all honesty though, i feel the turbo is a little laggy for my liking. I may end up down sizing the turbo at some stage, or maybe just hunt down an externally gated .63 housing for it.
That link was just an example, I'm not saying to buy it, I'm pretty sure I saw a a complete rb25 long motor for sale either here or boost cruising the other day for 1200, you would expect to pay anywhere from 1000-2000 for a decent condition engine. Totally worth while to have the extra cubes down low as well, much nicer to drive off boost then an rb20
Ahhhhh I see. I had no idea they're so cheap!!! I might have to do this hey. I think it'll all be in the compressor housing dude or yeah if its more than that just research the best combination for the 25.
If I've got a lightened fly and HD clutch, will an rb20 gearbox cope with an rb25?
Edited by EXEMPT
Depends how you drive but likely not. I killed a couple of RB20 boxes with only 183rwkw, first one behind the RB20, second behind the RB30 (the second one died real quick.. I don't think it liked so many 2nd gear clutch drops :laugh: )
I might have to get someone to look at my gearbox coz im pushing a fair bit more than that atm. Gearbox feels solid as all hell but I mean Murphys Law will come into play as soon as the rb25 goes in, if it does lol.
Cool. I'll have my mechanic confirm I've got an rb20 gearbox next Friday.
Is there anything that is obviously different on the outside of the two boxes that will indicate 20 or 25 box? I'm only asking because the car runs 230rwkw on 20 psi and has done for a long long timeand hasn't complained at all. Only when I le the clutch out before I complete the shift pinch.gif
Is it torque or power from the engine that wears a gearbox?
Edited by EXEMPT
Torque, power is just a function of torque and revs (and a constant).
Physically, the RB25 is SHITLOADS bigger than the RB20 box. If you have a look down the transmission tunnel and the gearbox barely fits.. it's probably an RB25 box. Couple of other things like how the slave cylinder bolts on and the speedo sender is one the bottom of the output shaft on one box, and on the top on the other.. can't remember which way round it is though..
If you need me to, send me a PM and I'll have a look under the car when I get home :)
Noo shit. Well that should be a fairly easy diagnosis then =) I'll be sure to check it out when I'm home in a coupla hours. If I can't make my own mind up I'll snap a pic and post it up lol.
Cheers dude.
heres how you tell which box you've got;
RB25 box on the left, RB20 box on the right.
you can tell the difference straight away. the rb20 box is noticeably smaller and it has some differences in the housing.
in your case, buy a half cut - it will be much cheaper than buying everything separately. it should cost you around $3000-$3500. i also recommend doing a leak-down and compression test before anything. if the motor is in good nik then the gearbox that is attached is more than likely to be in good nik, i.e. not abused.
Very nice bro thanks for your wise words also! I can see this happening in the months to come aha
Definitely buy a half cut if you don't already have a 25 box in there. People over here want $1500ish for the gearbox alone. I then had a custom 2-piece shaft made up (to handle huge torque), that along with a new slave cylinder and some miscellaneous stuff, brought the gearbox conversion to around $2500 and that's with me doing all the labour.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
