Its a girl (again)
Thanks Andy :)
Following closely behind Matt (Bugalugs) Deb & Tayah!
Tania started contractions around 7.30am Monday morning, & finally @ 6.10pm that evening little Jasmine Emily was born :) :) :D Jasmine weighed in @ 6lbs8, was "also" 49cm long, & very close to 33cm head circumference!
Mum & bub are both doing really well :)
Bug's & I both with the first name Matt, both with R33 GTS25t's, & both have girls nearly identical in size!
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-59420
Originally posted by whatsisname
Thanks again guys :)
Shell,
         Don't do it girl! You'll end up watching all the crap on TV @ 3am in the morning :):D
Congrats Matt! :)
Jasmine was top of our list if we had a girl.
How bad is the TV dark o'clock??? :confused:
heh, now I offer to do the feeds only when RAGE is on :(
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-61957
Choosing a name you both like isn't easy hey!
Tania didn't want to know if it was a boy or girl till the actual day! Lucky it was a girl 'cause we were both set on the name Jasmine from the start :) A boy named Jasmine….hmmm.
The child restraints "may" get used in the Skyline, but it's unlikely. The RAV4 does all the domestic duties :)
Free to air TV in the wee small hours is pretty dodgy stuff :D Yeah RAGE is one exception, good thinking! Oh, & F1, MotoGP, Indy etc... Mind you those don't really qualify for "dark o'clock".
Cheers & thanks again :)
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-62291
Originally posted by red900ss
heh, now I offer to do the feeds only when RAGE is on :)
haha Dino you can't just do the weekend shift - that's not fair!!!
the weekday line up is very sad :D
although on Thursdays they have that crap they call football on at about 2.30am (AFL footy show).... oh oooops I'm in the SA section *they like it here*
/runs and hides.... :) :)
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-62296
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
