Its a girl (again)
Thanks Andy :)
Following closely behind Matt (Bugalugs) Deb & Tayah!
Tania started contractions around 7.30am Monday morning, & finally @ 6.10pm that evening little Jasmine Emily was born :) :) :D Jasmine weighed in @ 6lbs8, was "also" 49cm long, & very close to 33cm head circumference!
Mum & bub are both doing really well :)
Bug's & I both with the first name Matt, both with R33 GTS25t's, & both have girls nearly identical in size!
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-59420
Originally posted by whatsisname
Thanks again guys :)
Shell,
         Don't do it girl! You'll end up watching all the crap on TV @ 3am in the morning :):D
Congrats Matt! :)
Jasmine was top of our list if we had a girl.
How bad is the TV dark o'clock??? :confused:
heh, now I offer to do the feeds only when RAGE is on :(
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-61957
Choosing a name you both like isn't easy hey!
Tania didn't want to know if it was a boy or girl till the actual day! Lucky it was a girl 'cause we were both set on the name Jasmine from the start :) A boy named Jasmine….hmmm.
The child restraints "may" get used in the Skyline, but it's unlikely. The RAV4 does all the domestic duties :)
Free to air TV in the wee small hours is pretty dodgy stuff :D Yeah RAGE is one exception, good thinking! Oh, & F1, MotoGP, Indy etc... Mind you those don't really qualify for "dark o'clock".
Cheers & thanks again :)
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-62291
Originally posted by red900ss
heh, now I offer to do the feeds only when RAGE is on :)
haha Dino you can't just do the weekend shift - that's not fair!!!
the weekday line up is very sad :D
although on Thursdays they have that crap they call football on at about 2.30am (AFL footy show).... oh oooops I'm in the SA section *they like it here*
/runs and hides.... :) :)
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-62296
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
