Hi
i have got a manual R31 that i am wrecking. it is still a running car so if you are intereted in anything you can come have a look. would like to keep the manual conversion complete and everything else is for sale
R31 full manual conversion including everything, tailshaft, gearbox, clutch, flywheel, gearbox x member slave cylinder, consol the works $700 ono
anything else you are after let me know and we can try and sort out a price
contact on <removed> and i am located in Belgrave Vic
https://www.sau.com.au/forums/topic/358585-wrecking-r31-manual-vic/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
