Stagea Transmission Oil Filter
Deepak78
 Share
Its a Jatco transmission same as R34 Skyline similar year 300ZX,, some Nissan utes Patrol?.. Doesn't your local parts store have a listing for Stagea? If all else fails you don't really need a new filter as its metal and you can just clean it with stiff brush.
These are numbers for S1 but you have an S2
tranny part codes:
RE4R104E is the trans.
3172841x02filter
3152641x07 oring
3139741x04 gasket
You may have a slightly different trans.
Heres how to change the fluid:
Changing the atf is not a simple task but you can do it yourself. Dropping the sump on the auto box will only yield around 1 or 2 litres but at least then you can clean the fiter (its steel) and pan and then put it back together. then take off a hose from the transmssion oil cooler and run the engine until you have collected a couple of litres. Stop the engine and pour 2L of new atf down the dipstick (for the auto trans ) and repeat til the oil comes out clean. Could take 10 to 12 Litres.
Hi,
Thank you very much. I live in Finland, and we have total 5 nissan stagea in country. So every part what these cars need have to oder out side.
Thanks again
OK well don't bother with a kit just pull the sump off carefully and you can probably reuse the gasket and take out the metal filter (its really just a screen) and clean it and put it back together and then change the fluid as per above - you will need about 12L so if you can buy a 20L container of preferably syntheitic or semi-synthetic automatic transmission fluid you can use that for the auto, the attessa and the power steering.
  • 7 years later...
tranny part codes:
3172841x02filter
3152641x07 oring
3139741x04 gasket
In regards to fluid change - This is what I’ve done on autos before -
just to confirm though if you take sump off and lose approx 2 litres and the. Pump 2 or 3 out of the lines - why would it take 12 litres to fill?
FYI - for a series 2 auto transmission
My local repco provided the local part numbers:
Filter - NXF17520
Gasket - NPG5000
Edited by H@ME
Added information
I keep dumping and refilling until it runs clean...that's what it took me.
 Share
    • Updating results.  Using ATR45SS-0 model VS UHF57-900. Those two are very different turbos, different wheels sets with different wheel hub profiles but yet with almost identical result. I’m intrigued with both turbos performance. ATR45SS-0 was a 61mm turbo first developed in May 2020, UHF57-900 was a 62mm turbo developed in March 2024 as a powered up alternative of a G30-900. On paper ATR45SS-0 maxed at 563rwkws, while UHF57-900 maxed at 568rwkws. ATR45SS was slightly more responsive with slightly better power band through the mid range.  Road driving ability, ATR45SS-0 had better throttle response, felt more robust under throttle, as it wakes up earlier. I think G series wheel hub design made it to have higher inertia under light throttle. Doing bit more prototype work in the next few weeks, will update result when its back on dyno again. ATR45SS0 Blue, UHF57-900 Red Chequered tuner's Dynapack hub dyno, E85 fuel. Mod list is in video below video_20240604_114214.mp4
    • Did you run the power cables for the mac valve to the other side of the car near the fusebox? Utilizing the stock boost controller cables? or did you run new ones?
    • Hey I have a potentially stupid HICAS question 🤣 I'm currently doing a full hicas delete, Power steering pump modified to non hicas, all lines removed from the car along with all electronics. My stupid question is - Do I need a lock out bar? is there any reason why I cant just remove everything from the rear end? I already have a lock out bar but thinking to save a few extra grams I could also get rid of the arms and tie rods as well and just run it with nothing in its place? or would it have a negative effect on handling?
    • Hi how are you guys?  I know i have been absent for years but im coming back slowly guys just wondering if anyone know where the ball joint on the NISMO arm front and rear can be replaced with OE parts?  Also  i know this is not the thread looking for springs and blistein shocks for the 260rs. Please advcie     cheers    yudy
    • Hi i do you have for stages 260rs?
