Hi Guys,
I have my HKS 2835 Pro S kit for sale.
Had it for a year and made 275rwkw still in good condition.
Kit Includes: turbo, dump pipe with O2 sensor, oil and water lines, heat shield, 4 -> 3 inch reducer
Price: $1500
Located: Northern suburbs
Dan
0401372748
https://www.sau.com.au/forums/topic/358829-hks-2835-pro-s-turbo-kit-for-rb25/
Very tempting at that price... I have the KAI (new version) of that turbo, and its not performing as the Pro S does, but havent heard back from HKS yet as to what they make of it.
Half tempted to just Buy this and swap and sell the KAI. Might send an email off and see if theres any progress in Japan.
If someone else beats me to it then so be it :)
Free bump for you anyway
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
