Hey all,
I had a power FC in my car and my car would start about after a second, 1 - 2 turns of the crank. Now I took out the power FC the car needs about 8 - 10 turns, when warm, to start and now it idles really rough, almost feels like a lumpy cam with revs constantly dipping. I thought maybe dirty AAC but if a power FC can hold a stable idle with dirty AAC then the standard ECU should do it alot better.
I suspect something to do with my cas or timing could be off. Anyone have any idea? Holding the throttle open while starting does no difference either.
Car is a series 2 r33 gtst.
https://www.sau.com.au/forums/topic/358992-standard-ecu-makes-it-hard-to-start/
check the coolant temp sensor for the ecu, might be playing up, making the stock ecu think the engine is still cold when its actually hot, this means the start up mixture will be too rich making it hard to start.
does it blow any black smoke once the stock ecu fires up when warm?
No smoke at all. None of my ECU's on this car caused excessive smoke. Its retarded. I dont know why it does it but all I know is when I add my power FC in, the problem goes away. Guess ill just wait til we get the car tuned with the PFC and mods and hope its gone. I really do think it has something to do with the CAS though, I did fiddle with it a while back and not sure if I put it on right lol.
Now I got another f**king weird noise coming from the car. It kind of sounds like a metal ting, does it when the car is idling can be heard from underneath the car so I gotta sus that out tomorrow. Sounds like someting loose or touching something it shouldnt.
Does it get quieter/louder when the revs are increased?
Because it runs fine with the power fc it shouldnt be a CAS issue.
Its a really hard sound. There are two new sounds. One sounds like thick steel wire just being dragged around. Sound does not change with revs. The other is only at bare idle, any touch of the throttle it goes away.
This is the new sound. You can hear it as the higher pitch jig jig jig sound.
Did you get this one looked at?
http://www.skylinesa...eo-and-help-me/
Sounds bad to me, I'd be concentrating on it ASAP.
I know what that problem is, its coming from the rear of the cam gears. If I apply medium pressure to the back of the plate(above the venting gaps), the sound goes away. Its apparently not too uncommon with skylines. I'll get the problem clarified with Advan.
So what modifications have you done to the car?
Well now Ive got everything I need its just a matter of installing everything. First off is the clutch, then the turbo, then injectors and ECU.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
