  • Replies 55
having tried the various LC modes I still think the original JDM spec launch was the best (certainly the most entertaining). I know they keep sprouting that LC2 was better but I think that was just to placate pissed off owners who had their LC taken away. it as piss easy to use (RROff), then just foot on brake (doesn't have to be super hard either) and then just push the accelerator to the floor (no need to stomp on it, or pump it or anything stupid like that). revs would hold nicely at around 4,800rpm and when you were ready you simply lifted off the brake which acted like a "go" switch. all you needed to do was be ready with the right paddle as 1st gear limiter comes up bloody fast! there was a bit of wheelspin which was probably a good thing for the driveline but the thing just rocketed off the line. I saw something like 1.2 accel g doing launches that way. and plenty of smiles too. :)
Spot on. Makes no difference in launch RPM whether VDC is on or off in the LC2 cars. (All ADMs). Only diff is that you have no warranty if you do it with VDC off. Go figure.
In regards to the 3.3 second time that would be 0-60MPH not 100 kph and I've only ever seen that number in Nissan's own videos. As far as an ADM doing 0-100 in 3.3 tell your dealer he's dreaming!
OK
The attached video has Mizuno showing a 3.3 on the whiteboard for the 2010 model using the LC2????
Also, I am midway enhancing my car and wondered what I could expect from the following;
Got full Willal Racing Ti cat back system
about to install dump pipes, AAM competition air intake system and new Cobb Access Port with both engine and transmission tune.
Does the Cobb system change the LC and what have other GTR owners experienced with the above mods?
agreed LC1 was the real deal
however it also netted countless grenade'd boxes
the LC2 'soft' launch isnt as aggressive and (arguably) a tenth or 2 slower, but it is less taxing on the drivetrain and technically still covered under warranty
yeah, agree it was not kind. on most roads it was ok as you got a bit of wheel spin which reduced that shock load, but I think with some cars suffering axel tramp (i personally never did) and some cars on grippier surfaces would have been those that suffered box damage. those 2 problems really come down to surface though I guess and it's impossible to have something that suits all conditions. I do miss it a bit, it was great fun on the road and looked and sounded pretty dramatic. :)
I had LC2 on my 09 R35. But it was wierd. Left foot on the brake and floor the throttle, it would only go up to 2500rpm. You needed to quickly let the throttle go and stomp back down to get it up to 3000rpm. Certainly never got times near 3.3 or the claimed 3.5 here in Queensland.
So all the numbers quoted has me confused. As I remember it, LC1 could only get up to 2000rpm with VDC on, but 4500rpm with VDC off, but it shreds gear boxes and voided the warranty.
I was never able to get 3500rpm with my LC2.
The series III is supposed to launch from 4000rpm as I recall, where did the figure of 4800 come from? Anyway, i'll be able to tell first hand after another 1500km's and i finish the run in period.
LC1 was 4,800 if my memory serves me (I have some vids somewhere of me doing it, I'll check). and yes it was with VDC off with trans and suspension in R. it was a pretty good balance between wheel spin and traction on every surface that I tried it on. wheels would turn maybe a couple of revolutions then it was 1st gear limiter in a hearbeat, grab second and off it goes again. I would say mid 3 second 0-100 times were easily do-able with LC1. hopefully now that's back with LC3. and I didn't have any gearbox problems. Fuel use and tyre wear was pretty fierce though!! :)
the bog came later when you had digested that ubiquitous cold potato salad
Brekky was nice but the lunch was just sandwiches and wraps.... Thanks god it was all hygenically prepared...You wouldnt want to use the PI bogs.....
Got some interesting news!
Did the Philip Island track day, got to speak to Mizuno San about the LC2 in my 2010 and he confirmed that If I launch it in the VDC-R mode ON, it will launch at just over 3,000 RPM and is covered under warranty.
Got back today, took the car for a drive and for the first time ever I launched it exactly as Mizuno San said. It works a treat!!!!
Not that I would ever use it again?
But, just in case I now know it works and I am covered!
that is great news!!
I'll give my gtr a try later....
Just make sure that you slap your foot hard and quick down on the go pedal after you left foot brake, any slowness in the move will stop it going into LC2 mode.
Also, I did it in Manual mode.
Have fun?
Have fun?
gave it a try last night with 3 R on.
It didn't got pass 2500 rpm and was climbing up slowly...
guess i failed...
The car did dash out after 0.5 sec later when i release my brake padel...
guess i failed...
Mmmmmm?
Are you sure your car has LC2?
Maybe check with the dealer.
On page 1, Martin mention it's LC2.
But I'll give the guys at Nissan GC a call.
In spite of what Martin said, Mizuno-san told me the LC2 launch in VDC-R was only made available in the 2010 model.
Could there be two versions of LC2, the latter being in the 2010?
Good luck!
Try releasing the throttle quickly and stamping it back down. Should get you to 3000+ rpm. Let go for only a fraction of a second, as short a time as your foot can manage.
There's no GTR that doesn't have launch control. Just that LC1 voids your warranty, and they're only available on grey imports. LC2 can definitely be done with all Australian standard GTR's. And they are MY10's, that's just the designation not actual production year.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
