i believe the rears are going to stick out past the guards by around 10-15mm
use the following link to see what youve got ( unfortunately it doesnt do half inch graduations , you have to guess that bit )
http://www.jonathanrowny.com/page/offset-calculator
Edited by Trick V35
you can try a camber kit but it will ruin tire life in a hurry.
you could get your guards modified but it could look ugly.
or you could find someone with a coupe that wants to buy them off ya.
try them on for size first.... you may just like the look of rim poke.
guess I'll soon be seling some nice rimz
I know the sedan has a little less room than the coupe, but I still don't think that size & offset you've got will be too big or aggressive at all mate... There are guys running 10.5" in +0 or less offset with just some tweaking of suspension, light guard roll & right tyre size so you have HEAPS more room compared to them...
Sorry, my bad.... just done all the measurements on my own car and yes the offset should be just right.
Rear rim poke will be about 7mm with standard suspension..... but if you lower the car, it will tuck under.
I'd fit a 245/35/19 tyre to the rears...
should fit no drama!
if not ill buy em for track rims. :P
20x12 -3 will be going on my coupe rear soon....
JUST REALISE I MADE A MISTAKE ON THE FRONT OFFSET IS 20 NOT 25
AND YES IM NOT KEEPING THEM AS SOON AS I SELL THEM IM GETTING SOME WHEELS WITH PROPER OFFSET
AS I FOUND ON G35 SITE
1st GEN G35 Sedan OEM Wheel Specs
Sport Model (2003-2004) & Non Sport Model
Front & Rear: 17x7 +45mm offset
Weight: 23.2lbs
Sport Model (2005-2006)
Front & Rear: 18x7.5 +45mm offset
Non Sport Model (2005-2006)
Front & Rear : 17x7 +45mm offset
Commonly used after-market offsets:
All first Gen years
Front width: 8.5" +29-30mm offset
Rear width: 9.5" +35-40mm offset
Rear width: 10" +42-45mm offset
245 series front tire and 265-275 rear tire are most commonly used
  • 10 months later...
Sorry to bring up an OLD post but I am looking at Factory (19x9 +47 F and 19x10 +30 R) 370Z 19" wheels
Any clue these will fit because I reckon they will look sweet on a V -Series sedan?
Nope. Do reckon they'll hit your suspension.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
