Hey guys,
I'll spare the details and get to the point,
I'm buying a used R34 GT, after I pay for it, I have to wait 1 week before I can drive the car away due to them needing to register for Roadworthy (They give 1 year free), is this normal?
Should I be worried they might change parts, etc?
Any help is appreciated.
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/
Ok, so what should I be asking them to do?
This is my first time buying a car, I have read through the "I'm buying a Skyline... What should I look for?" thread and have checked and test driven the car going through those steps, a lot of them the dealer did without asking, he was even willing to floor it in a 70 zone.
How long does it usually take for the car to be registered and RWC?
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/#findComment-5742151
Didn't the car have the rego sticker on it when you inspected it? I think something shonky is going on. I hope you remember what was on the car so that you can recheck it once you drive it away. Good luck.
I haven't payed for it, nor made a deposit.
I took a few pictures of it, and the front windscreen was clean, no stickers on it.
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/#findComment-5742202
Hang on;
I've bought 2 cars from power road over here in Victoria and they've been perfect.
Sometimes the cars the dealers buy sit in the yard for a while before they send them off to get their rego done... it could just be this. When i bought the GTT last year
It had literally just come off the boat and it did not have a rego on it. I think the neccesary mechanical work had already been done before it arrived in Australia however. I put a deposit down; it was put through the relevant Vicroads tests and after a week it was in the yard ready to go with its rego plates & tags; with a years warranty from the dealer.
In the case of rego; i think they simply don't have it on the cars sitting in the yard because if nobody buys them; the rego expires and they have to pay again...
Hope all goes well with your r34. If it's near 100,000km the dealer would have to change ALL of its belts free of charge before he sells it to you.
And if you're still paranoid; do an racv check (or the equivilent for your state)
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/#findComment-5742272
Hang on;
Hey,
I actually gave them a call and this is exactly the case, thanks for your reply.
They will be registering the car on Tuesday, so I can drive it away if I buy on Tuesday, the car is a late 2001 model series 2, 65K on the clock, very good ride, I hope all goes well, will keep you guys posted. :)
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/#findComment-5742309
Just dont pay for it untill tuesday then, if your a genuine buyer i'm sure they will get everything ready for you before you have laid down the cash.
Hope it all goes well for you. So what made you buy from a dealer just out of curiosity?
Not really sure actually, warranty?
I see more benefits buying from a dealer opposed to a private seller.
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/#findComment-5742558
Stoked!
Good luck trying to sleep in the nights leading up to tuesday.... i sure as shit didn't.
But since it's a 2001 model car; you should actually get a years warranty on certain parts... not brake pads or solenoids but if the engine blows up basically you are covered. I remember Shane telling me it
was mandatory on cars ten years old or less. You've bought it at just the right time. But since its got 65k on the clock whats the worst its going to need? wiper blades? pfft. Good luck with your new toy
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/#findComment-5743087
If the car is fresh into the country, then it's a few days wait to get a booking at VicRoads for the ID inspection - I learnt this one myself recently. As much as I normally love to sink the boot in when it comes to dealers, this doesn't sound out of the ordinary to me.
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/#findComment-5743235
Stoked!
You really reckon its done 6500km/year? :rolleyes:
Got logbooks? :P
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/#findComment-5743236
Well, thought i might post an update, the dealer is indeed 100% legit, but unfortunately I had to lend 20K of mine to my parents to put on a deposit for a house loan.....
For the mean time I will just buy a cheapy 3-5K and use it until I get off my P's and just buy a turbo Skyline.
Would also like to thank everyone for their input and time :)
https://www.sau.com.au/forums/topic/359513-dodgey-dealer/#findComment-5751544
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
