Sold my ride so I've got some of this :yes: .
I want an R32GTST in nice condition manual prefered but can be auto only criteria is must be good condition.
Well done mods are OK but keep the shitty flogged out ones, I don't want them.
Will travel for the right car if I have to.
Please PM me if you have a nice one to sell and want the cash with no mucking around.
https://www.sau.com.au/forums/topic/359578-wtd-r32-gtst/
hey man im selling my skyline 32SXC
with 32sxc plates lookin for about 10k ono
will b postin an ad up later tonight but heres a few specs for now txt me on 0402 547 310 if ur interested
306rwhp, dyno sheet to prove
rb25det upgrade from r33 s2 and gbox, 150xxxkms
hks fmic, apexi 400hp ballbearing turbo, fullboost (14psi) at around 3500-3800
TRUST full 3inch turbo back zorst
BLITZ dual stage sbc & turbo timer
z32 AFM
Greddy Radiator
shimmed vicous lsd diff
glowshift 7color gagues oiltemp, oilpress, watertemp, boost/vac
twin plate brass button clutch
tien ha's height and dampner adjustable all round
rays 17x9fronts, 17x10rears
https://www.sau.com.au/forums/topic/359578-wtd-r32-gtst/#findComment-5742827
z32 AFM
Greddy Radiator
You have PM :yes:
https://www.sau.com.au/forums/topic/359578-wtd-r32-gtst/#findComment-5743021
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
