Covered a million times on here before and i have done a search as well..
But basically my new r33 gtr skyline's injectors are leaking from around 3 of them, 2 being at the top of the injector and the other from the bottem..
One of the ones that leaks from the top (nearest to front of engine) just pours out constantly..
Whats the best solution to curing this? car is stock with stock injectors.
Should i just take it to an injector specialist in bunbury (although i dont any) can anyone reccomend anyone? so they can clean and put new seals on (hoping that they are not cracked) and clean them...
Or should i just buy later injectors off a r34 gtr???
https://www.sau.com.au/forums/topic/359711-leaking-injectors/
If it is leaking from the top, then a set of o-rings should sort out your issues.
What you will probably find if it is leaking from the bottom is that it is coming from the centre section of the injector body, where the plastic casing and metal assembly meet. From dim and distant memory mine looked like it was coming out some sort of casting flash on the side. Had 2 leaking I think.
If that is the case, then either isolate the leaking ones and replace with tested good ones, or use it as an opportunity to upgrade.. I bought a set of 700 sards, and to go with it a PFC, and to go with that, a set of -5's, and to go with that........ :blush:
Yeah thought so, gonna read up on how to take em off and inspect them myself...
And then find some were to fix em unless it seems an easy fix then its justa case of getting new o rings hey...
Incorrect sizing??
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
