Hi all ,
Saw a guy had a bride replica seat at the Dyno day that just passed in his red M3 and it looked really good , so im considering getting it soon.
http://www.justjap.c...&cat=282&page=1
Has anyone tried fitting one of these in theyre 32 / what sort of modifications am I looking at doing / is there any welding to be done??
I phoned justjap and they said even if i get the skyline rail i will still need to modify it to fit the actual seat.. so ill just use the rail alredy on the car.
If anyone can help me put it in , i will buy you allot of beer :)
Thanks
John
https://www.sau.com.au/forums/topic/359789-bride-copy-seat-in-32-gtr/
I've got a similar one in my R34.
All I had to do was to get a Recaro rail (thanks to JDMPWR), it bolted straight onto the seat and since the rails was made for R34, it bolted straight onto my car.
No problems at all :)
Those universal rails that comes with aftermarket seats will never fit your car without any mods.
But to be honest, these seats are awesome, hugs the shit outta you around corners, but if your car was a daily, I'd reconsider lol and think about Recaros instead....
It's SOOOOO bad to get in and out of, especially you don't wanna just flop onto the seat everytime you get in and out as you try to avoid the bolster tears lol
Oh and to be precise, those are Recaro SR3 rails to suit R34.
As the SR3's mounting holes are in the exact same position as the Bride style.
They can be found 2nd hand for anywhere between $50-200 lol
Even a skinny person like me, I have to support myself by pushing up against the door jam to get in and out. And it sucks when I park in a very tight carpark with a car next to me :(
But when I'm turning corners in it, it is AWESOME, I don't even sway one bit lol
Is your seat from holford Motors or jj charlie?
Damn they look so good man! Thanks allot for the info , ill look into getting those rails for my 32.
Would 34 rails have the same bolt patter to go on a 32 floor??
just buy a cheap generic low mount rail and drill the holes to suit. heaps cheaper than buying a genuine rail
Bought it from a dude in Frankston, brand new lol. It owns the Drift Blades :P
It's heaps awesome man, for the price you pay and the comfort you get, unbeatable. If you are around my area, you are more than welcome to come see it in real life and have a sit in it lol.
And no, R34s have different rails to R32,R33s.
It's not just as easy as drilling a few holes...
Those universial rails won't bolt onto the car properly without mods, let alone bolting onto the seat. And you wouldn't wanna be modding the rails, as things could go bad during an accident.
And drilling holes in universial rails to fit the seat might not work, as the rail's mounting brackets might be too far or too close apart, which won't line up with the seat.
The amount you spend on a cheap unversial rail ($50-100) and the time you spend on modding and the risk you take on modding, I'd rather pay extra $50-100 to get proper rails.
Having said that, having a replica seat can also be a risk during an accident lol
the only difference between a universal rail and say a r34 specific one is the shape of the mounting plates essentially.
i dont see how drilling your own holes is any different to using the existing ones. its still a thick bit of steel bolted to the floor no matter how you do it.
Well depending on the universial rails I guess, but I think some of the times, you will find that the mounting brackets are sitting so far from the mounting holes that you will need to modify the bracket, eg cutting and rewelding or welding an extra bit of metal wit hole to line up with the car.
lol there is no way in hell that the universal 'rail' (which is in-fact just a sliding mechanism, no base) will fit into a skyline without some welding.
John the jjr rail will work, you may need to drill your own holes in the jjr rail to mount to seat to, that is it. But they mount the seat pretty high.
And you can't use the rail that is already on the car, as you will need to re-weld/cut/hack it up to mount it to the bride style seat.
The ///M runs one of these (to fit e36), I run one in my car as well.
http://www.nzkw.com/index.php?main_page=product_info&cPath=104_93_96_130&products_id=250
Attach the slider that comes with the seat onto that base, nice a low. easy.
Buy the seat and then buy the genuine bride rail for that seat and it will fit in the r32 no worries. Ive had both the copy and genuine brides run on the same rail in my r32 gtr gtst and r33 gtst no worries. This was with the bride gias seat similar to what you have...No cutting or welding requried.
Man, my asian hips struggles a little to fit in it and I weigh 55kg lol
They are heaps tight
Also, instead of getting from JustJap. Hollford Motors (think that's what it's called) in Melb sells the same seat but with bride logo on it lol
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
