I NEED HELP!!
I have a 1990 R32 GTS-T and something is wrong with it and I cant work it out...
I've only had the car for about a month now and it was running beautifully when I first got it but then all of a sudden a problem has developed with the boost...when I first got it boost would come on at about 4000rpm on full throttle, but now when it hits approx 10psi the car splutters violently and just bunny hops and does nothing but if I keep my foot down long enough then the boost finally kicks in. (For some reason everything works the way its meant to in first gear, sometimes...) Also if I just drive normally not making boost the car drives fine. and it is using an insane amount off fuel as i'm only getting about 200kms to a tank and it puffs black smoke out the exhaust when I try and hit boost.
Ever since this started happening I replaced several parts trying to fix it including;
- BOV
- FPR
- Coil packs
I was thinking of replacing the Wastegate next..
I've inspected all hoses and lines and they all seem fine, also inspected the spark plugs and are all good.
P.S. The car has a Hypergear ATR43 turbo and is tuned to 15psi
https://www.sau.com.au/forums/topic/360109-helppp/
Try lowering your spark plug gap if it already isnt , should be running bcpr7es at 0.8, also did this probelm start out of nowhere or wasnt when turbo got put on at and boosted to 15psi dont know if r32 ecus are like r33 stock ones and hit r and r when boosting over 10-11 and if all this isnt the problem maybe check your coil pack harness and regards to fuel if it isnt tuned with a ecu or if it is tuned then its a poor tune to be getting economy like that.
https://www.sau.com.au/forums/topic/360109-helppp/#findComment-5749710
We checked the gap when we inspected the plugs, its at that...and technically speaking it only started once I took it to an aircon place to get a hose replaced for the aircon, then once i got it back it started doing this. I took it back to them complained and asked what they took off to do the job and check them in particular and it all seemed fine...the harness as brand new, no cracks or splits...and i have a nistune ecu installed, i was getting close to 600kms to a tanks when i first got it and no there are no leaks, i have replaced the fuel filter and am running a Bosch 040 fuel pump
https://www.sau.com.au/forums/topic/360109-helppp/#findComment-5749723
Check the voltage on the AFM when you are boosting. If it exceeds 4.9V you may be hitting factory boost cut
...edit.... and when I say boost cut I mean ignition cut relative to boost/air flow etc
I will check that when I get a chance next
As well this car was in with you guys not too long before I purchased it, and reading through the receipts it had some kind of misfiring issue. Is it possible this issue could have arisen again?
https://www.sau.com.au/forums/topic/360109-helppp/#findComment-5751454
If it's idling high, check for vacuum leaks after the throttle body, INCLUSIVE OF THE AAC/IAC. It might be faulty/thrown out. Only way idle can go up is for there to be more air getting in, so if the throttle plate is still closing then you have a leak somewhere behind that.
EDIT: could also potentially explain the lag with boost and then R&R - if boost is leaking out of the manifold after the throttle body, then for the manifold pressure to get to 10psi there would be MUCH more airflow through the AFM to overcome the leak.
https://www.sau.com.au/forums/topic/360109-helppp/#findComment-5751475
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
