Gday all, i just have a question. My mate and i both have 180sx and both have RB20's in them. Mods wise they are very similar in that there isn't really any. But when we are travelling at similar speeds are revs are very different. E.g when im doing 100km/h my car reads out that im doing 4500rpm while my mate at the exact same speed is only doing 3500rpm and they are both in 5th gear. Could anyone tell me the possible reasons for the difference in revs and could this be a problem.
https://www.sau.com.au/forums/topic/36017-whats-the-reason-for-the-difference/
im sure he knows what engine he has :D
they both got swapped for rb20's by the sounds of it. Sorry i cant help ya mate
yeah youd think so, but he said he and his friend have no mods.
why would you go through the effort of swapping the SR20 for the RB20 anyway? If you were going to swap to an RB you would at least go for the RB25.
Just to check that the tacho isn't wrong (as 1000rpm seems like a huge amount more for a 4.3 diff over a 4.1 one), do the engines sound the same when they cruise at that speed? I mean does your one actually sound like it's doing 1000rpm more than his? Since yours is slower, it does sound like your diff isn't some super high ratio one.
Im not the most knowledgeable when it comes to the mechanical side of cars, but can someone please explain what the difference is with the diff ratio and how it effects the car. Is it related to the gear ratio. Im sorry if this is a dumb question but i don't really know. Tah
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
