It was in the Sydney Harbour Tunnel a bunch of times over about 6 days or so.
Speed cameras are able to catch speeds up to 360 km/h I've been told.
A mate is a cop and in the training they get told if the radar has three dashes instead of a speed reading call the airforce cos it's over 360. I wouldn't know about accuracy at these speeds though.
i was reading the harbour tunnel camera goes to 300km/h and so far this year 4 cars ( 2 ferrari's, lamborghini and a porsche) have exceed this and the photo has been blured...how crazy on a bike but haha...
ben...
I'm surprised that one of our 4wd cousins did not 'represent'...
T.
Just a side note: Just because a bike's speedo reads 310kmh, doesnt mean its going over 300kmh. So if someone claims they pulled over 300kmh on their speedo, they may not have really cracked 300kmh. Hayabusas have been known to be "a bit optimistic"
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
