Hey well,
Well just for inspection purposes I pulled out the plug from cylinder one. Looks pretty good to me but just wondering if it could be a tad on the lean side as it looks a little too clean. Plugs are more than 6000km old.
My main concern was detonation issues(my other ecu was reading crap load of ping at times, shit tune). Car has been on stock ecu for a fair while, only had the other one in there for a day.
Any input would be great.
These are copper plugs so I'll be changing these with the same ones on next oil change.
Cheers guys
https://www.sau.com.au/forums/topic/360290-how-does-my-spark-plug-look/
  • 2 months later...
Well lets bump this up just for comparison purposes. I recently had a few things put on my car(see the rb25 dyno thread). I put this stuff on the car and it was about a month or two before I got it all tuned. Before the tune I pulled the plugs and oil and what not to ensure everything went in fresh. The plugs came out looking just like above, nice and normal.
Anyway got the car back and the problems started. I put the exact same model plugs in, gapped appropriately. 2 of 6 failed after 300km. Look at them now. I just put a brand new set in there because of the misfires and shit that the car has been giving me.
I have no doubt in my mind that this tune is pouring fuel into my engine... I'm going to take it back and I expect not to pay anything more to have it looked at because this is a joke. I'll be chewing through spark plugs everytime I go to fill up a tank of fuel by the looks of it. I'm not impressed at all really and I kind of feel sick to the stomach. I thought I made the right choice in tuner but clearly the tune shows otherwise.
And to note, when the two plugs failed, I replaced them temporarily with the old plugs up in the OP. The picture you see if the old plug up in my original post, it was driven on for about 20km.
ok so others don't have to go looking for mods because you were too lazy to post them i have quoted your post from the dyno section.
you say that the pump was failing during the tune and that you fitted another pump. was that done after the dyno runs? if yes that that is your problem and your fault and not the tuners. your tune was done with a failing pump and you have gone and fitted a working pump which will now be supplying much more fuel (higher pressure) so the injectors will be pumping in extra fuel.
Got my car tuned but its going back soon.
Anyway its an R33 GTST Series 2 with the following:
Unopened RB25DET
HyperGear ATR43SS-2
3" JJR Bellmouth dump
HKS Hi Power Silent exhaust
Yellow jacket coils
NGK Copper plugs BCP7RES gapped to .7
Genuine HDI FMIC
Venom 5" body 100cpsi cat
Nismo 740cc injectors
Bosch 040(was failing during tune)
Nismo FPR
Greddy profec b spec 2
3" metal intake with Apexi power intake filter
Power FC tuned by Advan performance
Made 244rwkw on 11.4psi. That is with the boost controller set to 100%. That is as much as we can get out of it. With about 15psi, we should see about 270rwkw and 17psi about 280rwkw. 20psi should see 300rwkw on regular fuel pump.
Ive fitted a GTR fuel pump in there to fix the fuel pump issues. Probably will swap that with a brand new 040 pump or run it as a lift into a surge tank. Last printed dyno shows about 238rwkw on 11psi, should have printed the previous runs :P
When I took the car to the tuner I had no problems with the car. The tuner said it will take him about a day to set everything up and test everything on the car before he tunes. He had to install my new injectors and setup the fuel pressure on the regulator, he asked me what fuel pump I had and I said a 040 and he said ok its all setup correctly to be run in on the dyno. When he was about to start the tune(I was not there at this time) he said the AFR looked strange at low RPM. He said it may be due to surging of the turbo at low RPM and that is nothing to worry about. After the tune was complete he said he is happy with the power it made at the set boost but said it can do with more boost. I took it home the next day and the pump failed. I did not know. He said the fuel pressure was good. The pump was priming. If the pump was failing he should have picked up on it. That is like saying one of my piston rings is worn and I didn't tell him. I payed him $800 to check my cars health and do a tune. He made me pay him to regap my plugs. He made me pay him to fix my PCV valve. He made me pay him to test my fuel. Its a f**king joke that anyone would think its my fault. How was I to know? I drove this car for 8 months without a single fuel related issue. The only real issue was my coils failing on me which I fixed my self. It was only after I told him the pump failed AFTER the tune that he did suspect the pump was failing during the tune.
When you go to a mechanic to fix a problem on your car, its up to them to find the problem based on your input. I told him what the car had, that it was fine. He ran the car on the dyno and say the poor AFR. He could have told me that he suspected the pump is going or it felt lazy rather than continue tuning and take my money.
Another guy on here had his car tuned, payed for it, took it home and it was running rich as shit. He then realized he had something unplugged(which he unplugged him self). He took it back to the tuner and the tuner fixed up the fuel map for free even though this was the car owners fault. I hope for my sake that this tuner will not take me for more money.
Edited by SargeRX8
the pump may have been failing by a small enough amount to not seem too bad (lets say 25% down) since all he has to work off is injector rates and every car will run different injector rates with similar mods. once tuned at that rate if a fully operational fuel pump put in it will run rich as hell (since it has just started adding in 25% more fuel). that is not the tuners fault in my opinion.
as for your tuner charging you to do work, that isn't that unreasonable is it? they are doing work, why shouldn't they get paid for it. if it doesn't solve the problem then they can't be blamed for that if they honestly thought it was going to help. often with car problems there can be many different causes so you just have to go through each possibility until it is fixed. sometimes you might get it first go, other times it might take you a day of mucking around. some people will be kind enough to fix stuff for free, especially if it doesn't take them much time to fix or they made a reasonable amount of money off the initial work.
the fact remains though, new pump is the cause of the running rich. had the pump continued working for a year then the tune would've been fine. it essentially is no different to a tune being out because a bigger turbo was fitted.
Do you think the fix could be as simple as adjusting the fuel pressure? If the pressure is set to 43%, how much impact would a fully operational pump have on pressure?
I can understand what you are saying but if I have to pay again for a tune and be out of the car for a week, its about harsh on me, isn't it? I'll be going there tomorrow showing them the plugs and seeing what can be done.
it could be a case of simply dropping the fuel pressure, however it will come down to whether it is rich all over the tune or just up high (which is most likely since the fuel required at low load is bugger all so even a dying pump shouldn't be leaning out at idle). my guess is that only the upper end of the tune will need to be altered and even this shouldn't require too much work, depending on whether they tune with the hand controller or with pc software
and yes i agree with the fact that it isn't really fair if you have to pay for a second tune.
Hey Sarge i hav to agree 110% with everything mad082 has said about the fuel pump and mechanics in general. Its a process of trial and error in alot of cases. Also agree with him in saying about the fuel pump throwing the tune. But i also know exactly how u feel about paying again.
Im sure if u ask NICELY that advan will help u out in rechecking/setting the AFR's across the board.
Just be sure to be friendly. Don't accuse them and get them off gaurd.
Let us know how u go today.
As polite and kind as I could be, he wants a couple hundred and the whole day to adjust the fuel pressure and tidy the tune on dyno... Is this right?
time frame wise it seems reasonable since i'm guessing that just dropping the pressure won't be enough since you still have to maintain a certain amount of pressure, so a lot of it will be redoing the actual tune. money wise i'd compare how much he wants to how much it cost for the initial tune. if it is much lower then i'd say it's reasonable. if it's clsoe to the same cost then possibly not
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
