hi guys...2 weeks ago i had a autobox in my cefiro and all run fine...now i got a rb20 manual in there and changed to a r32 ecu(thinking of buying a nistune chip^^)
the car runs really good, like always, idle is fine too when cold and warm...problem is if i drive down the road and try to stop i gotta clutch in lol
everytime i clutch in when downshifting or stopping the engine die >_<>_<>_<
sometimes the rev's drop to about 200-300rpms and then go up to the normal idle of about 600rpms but mostly when i kick the clutch in rev's drop just to zero and engine is dead!:glare:
the car is 100% stock, i got the aftermarked bov out, checked for leaks in the intercooler piping but nothing, idlevalve is cleaned too...
i'm going nuts, so pls community help me out :worship:
https://www.sau.com.au/forums/topic/360364-cefirorb20det-idle-problem/
Yeah manual is a bit different to auto...takes some getting used to :P
Does it do this after being on boost / off boost / both.
I'd say adjust the TPS unless it's boost related.
hmm i got no air/fuel gauge:(
and i got nothing to adjust too, i can buy nistune when the car is perfect^^...don't wanna buy now and then wait 2 months for money to get the car repaired >_<
lol it's not the first time i drive a manual,...thats not the problem^^
it's not just on boost, sometimes i drive 2000rpm and it dies...
i realize it dies everytime when i drive constant the same rpm a few minutes long and then stop...
btw with boost i got no issus,...it boosts great like always
nope no smoke,...but i think it could run a lil bit rich? maybe normal but i think it smells too much like gasoline out of the exhaust^^
gotta try to find a air/fuel gauge...btw does it has to be a expensive aem or does the cheap ones work too?
watertemp sensor is fine, the one for on the dash is find, but the another one for ecu i don't know how to check?
i love the way the emission fumes smell from Rb's really rich call me crazy lol
But the AEM's are good brand
Good Luck
I would say unless youre planning to go really into the drag and drifting the regular gauges will work fine
I have some regular gauges and they do the job ,been 2 years and no problems
They work well for my everday usage
As for yur problems as nic mentioned try another MAF and look into the mixture
Good Luck
i wanna really drift and use daily,...ok 200usd for these:(
but ok i won't need to buy these 5times a year:D
just ordered one @ aem
btw does it has to be a maf from a cefiro or a random r32 rb20det maf will be good too...
Not sure about the different MAF my advise is take the care where you would be buying it and try it to see if it works
I know some of the skyline MAF's work as they are skyline engines
As for the gauges youre good to go some years on that
If the AFM label is Purple and marked N60...it can be interchanged with Z32 300ZX [N/A only], J30 Maxima, or pretty much any Nissan with a VG30xx engine.
If its label is green, marked J60, it is interchangeable with R32 GTS-T RB20DET
If its not either of those colors let me know...but it should be one of the two, if it's not you got a problem.
i just borrow'd the maf from a friends friend and tested,...the same problem...>_<>_<>_<
now was thinking what i wouldn't need here and saw the cold start valve, here in thailand you won't get under 10degrees except you're on highest mountain here so got that piece of shit out and here we goooooo ideling alot better now :worship:
that f**king thing had a lil crack on it,...
i'm still waiting for the aem uego air/fuel gauge but i see a bit difference between the a31 auto ecu and the r32 manual ecu:
a31 stock ecu:
-idle is a tiny lil bit better
-but i waste a damn lot of gasoline!!! nearly 4 times more than the r32!:pwned:
donno but i think it's running hardcore rich to use that amount of gasoline...i had this one from beginning and car was drinking more fuel than i'm drinking beer in a month:D
-stock rpm gauge won't work with this one,...donno why?
r32:
-rpm gauge works surprisingly (i never touched the wireing!?)
-idle is a lil bit worser than the a31 but still driveable, not that bad...
-fuel economy is reasonable,...very good with that ecu...
from what i've read there shouldn't be a difference...abit confusing :closedeyes:
i had this problem.. give it some stick or even just drive through the gears. clutch it to roll to a stop and it would die.
Cas - advance it just a tad
Vacuum leak - check all lines
Throttle body. give it a good clean and make sure its adjusted properly
  • 2 years later...
I had the same problem on my car when I first got it, it is most likely a vacuum leak.
check and clean your IVAC and ACC also it should be a part of your maintenance anyway
And the simplest way to check for your leak is just to use carb cleaner and listen for a idle change to check for your leak.
Here is a video of what I mean: http://www.youtube.com/watch?v=9CPqbaSgcok
remember our cars are pretty old at this point so the hoses are just getting old so you might have the smallest crack in your lines so move them around to expose anything and check if they are getting hard.
This might help you out too : http://www.skylinesaustralia.com/forums/topic/174735-fixing-idlestarting-problems-rb25det-cleaning-air-regulator-easy-way/?hl=%2Bclean+%2Byour+%2Bacc
I have a 25 but search around if it is different on your 20
good luck and i hope everything works out!
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
