  • Replies 112
Dry manifold? Bottle heater? Electronic purge timing? Stand alone control panel or intigrated One's and Zero's...
GAH!!! What? Who? When?
No bottle heater, manual purge by holding half throttle with the door open and tapping the switch....erm..... you're confusing :cheers:
Adrian
lol.
I am running again next Wednesday @ WSID with the right plugs, better fuel (still PULP) and WITHOUT the two enourmous boxes of Krispy Kreme donuts, 4 litres of water and my video camera on the back seat. :cheers:
Adrian
hey adrian, well done mate, good to see you car is getting quicker. now i am really looking forward to racing against you :cheers:
btw. peak performance (nowra) are having a dyno night (thursday) in the next two weeks, i think its about 30 or 40 bucks to put your car on, i'll let you know when i find out the date.
cheers, mark
R31Nismoid,
Same tyres as last time. 99% shagged (now well and truly) Pirelli 235/45/17's but i let them down to 11psi and fried them hard. The 2.001 60' time tells the story.
Mark, PM me details when you get em please.
Adrian
hey adrian got my new clutch, and it grips like a mother ***cer, ill be there on wednesday after i get some more fuel,wasted it all drivingto the wrkshop, hope to get another run next to you, and some more pics. i also think i should drop the pressure in my tires to about 11psi, 25 is way to much what i used last time.
i heard alot of good things about ur car... congrats.... do u tune ur car for c16...if so what sort of gains are there to be made... ive always thought that c16 was bad for the cars due to its lead content... correct me if im mistaken, cause i was thinkin about using it at one stage but certain tuners would not tune my car with it..... cheers...make sure u kill it this wednesday night!!!
C16 kills ur 02 sensor and the tips of spark plugs
errr... not if you use the right O2 sensor and plugs.... thought that was pretty straight forward. also not great for catalytic converters.
Adrian
Guest INASNT
c16 is very bad, only driven 200ks on it and my brand new ngkr spark plugs are gone, need to change them, i hope with the new plugs and clutch might beat my shocking time, will see tomorrow.
And adrian is trying to say they dont effect spark plugs or 02 sensor?? Even the 107 octane suncorp fuel fouls your plugs quick
Did u get high off the fumes when u were pouring it into your tank??
Enricco, a guy with a hell of a lot more drag racing experience than me looked at them and told me 10psi. It worked and there was almost NO wheelspin when i slipped the clutch at this pressure.
Hoetrain, thanks dude.
Can you read? Re-read what i typed. Fark.
Adrian
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
