Item Summary: 1990 NISSAN SKYLINE gtr r32, heres my nismo gtr great car but need it sold as need funds
Postcode: 244
Odometre: 86,246 kilometres
Asking Price: $13,500
Condition: Used
Reason for Selling: need funds
Delivery Methods: PickUp
Contact Info: 0404203660
Extra Information:
hay here is my skyline gtr r32 nissmo for sale
$13500 ono with 6month qld rego
1990 r32 gtr nismo
86246ks on clock
coilovers teni all round
new tyres
16" racing wheels
3" cat back exhaust
3" high flow cat
twin pod filters with custom shield
polished rocker covers and some piping will get pics up soon
new plugs and timing belt / adjusters
sway bar
great interior sports steering wheel
nismo front bar and grill,
nismo cluster
nismo computer
turbo timer
boost gage
just spent $2800 on services got recipes
putting out over 200kw on rw tune have dyno sheets
Bad points
roof has faded got quoted for 350 to fix
rest of paint is pretty good for a 20 year old car
slight rust above rear wheels easy fix
very fun and nice car to drive :P goin to be sad to see it go
ary: [/b]1990 NISSAN SKYLINE r32 gtr nismoneed sold asap my loss your gain
https://www.sau.com.au/forums/topic/360390-skyline-gtr-r32-1990/
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
