Guys, next week.
Meeting will be held on the WEDNESDAY 17th MARCH 8pm
Not the usual Tuesday. Sorry if this inconveniences anyone.
Items to be covered
Entrants - All entry forms must be in by the end of the meeting.
If you have not paid you run the risk of not be in.
T-Shirts - All to be paid for upfront, final design to be on display etc.
Sample sizes also avaliable where possible.
Again, if you have not paid, you run the risk of not not getting a t-shirt.
Helpers - Roster will be drawn up, and distributed
Ladies - A sample shirt should be avaliable to check out.
Please bring a few dollars along for your tops too ladies :starwars:
This is going to be a very busy meeting.
Please be as punctual as possible. There are a lot of smaller things to go over.
Again, a couple of beers will be provided.
Any questions, post 'em here. Otherwise see everyone Wed.
- ash
https://www.sau.com.au/forums/topic/36042-must-read-mas-meeting-wed-17th/
  • Replies 58
ok this time we need to get a photo of everyone BEFORE people leave... so we can post it up and get everyone to put their REAL name up and nickname so we know who the **** everyone is... as well as at the meeting have a brief go around introduction... makes things a little easier... cause after all these meetings there is still a few people whom i have no idea what ur real or even nicknames are :D
No representatives were there this week. Ash has made an enquirey on their website but has had no real response. So basically we don't have a clue what they are doing. But speaking to Nige last night he seemed to think that someone was doing something!
D,  Don't worry bout us mate.  I'm working on the site with Jack and Ross.
Most things are under control.  A few fine details need to be ironed out but on the FA side, all is looking good.
We'll try to have a rep at the meeting on Wed.
Hey Dave... if James hasnt already spoken to you.
We need to have everyone paid, entry forms filled out, by Wednesday next week at the latest
This is so we can take all the entry forms to Cabin, and get the desired postion that we want.
As of next Wed, there is only 2 weeks left till the show. .
And we are cutting it very thin.
CR34TION - Good to hear from you. Your car is in, we just never seen ya at a meeting to confirm, so come along.
PM me for Sammi's address if you dont have it guys.
Adam you have already filled out your form and paid your entry so missing this week isnt super important for you. Just maybe send James a PM regarding the t-shirts if you want any. The main thing for this week is getting all entries and t-shirts numbers in and paid up.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
