I just got defected today driving my uncomplied unregisted r32 gtr from the mechanics back to my house on a permit.
I had no front bar because it was at the crash repairs getting some cracks fixed, and whilst i was driving it home my front right indicator fell off unknowingly.
the officer deamed the car unroadworthy and defected me. the car will be getting complied sometime in the near future maybe 3-6 months.
will this defect have to be removed (rectified) before i go to get complied or when its getting complied or after? or is it just nothing to worry about?
Thanks.
https://www.sau.com.au/forums/topic/361051-defect-on-permit/
There is a dedicated defect thread in this forum for questions like these. Otherwise we'll have hundreds of defect threads from various posters.
Expect this thread to be locked and/or removed.
You'll find your answer in the defect thread.
:thumbsup:
I wouldn't worry too much - I know this isnt the exact same situation but me and a mate of mine both took our R32's through Regency around the same time for a RB25DET conversion, his was defected, mine was not. I don't believe there was any difference at all in how the cars were checked and the owners treated.
Get the defect notice signed off once you go through so you can hand it into the rego office to get rego for your car.
You might have to pay more for it though as it's meant to be a different type of inspection to your ID one to gain rego.
Easy done though.
I would have laughed at the cop, as the car is uncomplied it is, and always was not compliant with ADR's and therefore is defectable. But as the car has to be complied you are in effect clearing the defect when you get it complied, just rip the sticker off, it means nothing in this case.
true.... but leave the sticker. its not worth the immenant fine that you would get
Rip the sticker off if you never plan on regoing the car but leave it on if you do plan on getting rego.
They would have defected the vin number of the car so he would need to get it cleared off the system so he would need to get his defect paper work sorted at the same time and removing the sticker wouldn't be a good idea haha.
as the car hasn't been complied, there is no VIN in the system. The VIN the car will end up with will be an 1MPORT xxx xxxx VIN which the car hasn't got yet.
Anyhow there is no harm in leaving the sticker on but i still would have laughed at the copper.
Those VIN numbers were issued with tho old Import scheme, It will be given a VIN, 6U90 - then your chassis no, more Zeros added to to take it up to 17 digits if required.
so if my vin/chassis numbers are in the system with a defect to there name, when they add onto the numbers for compliance it wont show that it has a defect on it when i go to get rego?
Thanks.
Thanks.
Im pretty sure when you take the car in for inspection, it wont be "on the system" yet as a car on the road. Doing the roadworthy to get rego is clearing it at the same time also, so once inspected, they would then add you and at the same time it would be cleared of any defect.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
