Hey guys,
Took my r34 auto non turbo in for a 'genuine nissan' service. I went to pick it up and they tell me that I've got a minor steering rack leak (its not leaking onto the ground) and the rod bushes are split so it won't past rego without being fixed. They estimated me $3100. Charging $110 for labor for 5 hours.
I think it's a total rip off, but what do you think? Know anywhere I can find new bushes?
Any help/advice is appreciated as it'd be saving me a lot of money....
Also, I'm getting a little steering wheel wobble at 80km+, the guy told me at the start a wheel alignment would fix it but then the service person said it was because of the other things.
Edited by sk8_lad
Fark $3100 for that stay away, I replaced my sterring rack in my R31 when it died (was slipping in housing) and also had a new cam installed and total was $1500 i think.
Repco or the like should have tie rod ends, just jap have longer ones to im pretty shore. and just give the rack a good clean and wait till it goes.
and yea a wheel alimenght is a good idea and wheel balance.
also look at other work shops, they may do it alot cheeper.
Lol $3100 get f**ked.
Ring up some steering rack places and see how much they do change over ones for. If its not loeaking on the ground then its not a road worthy item anyway, it sounds like its not that bad.
Which bushes are rooted?
Either way that sounds way to expensive.
Edited by eightsixboy
thanx for the advice dude. yeah they said the steering would pass rego inspections because it wasnt leaking on the ground but i still want it fixed cos well....im sure u understand :)
they just said all the bushes r split i think and that wouldnt pass rego.
but then they told me my brakes r 50% worn. i replaced them in january myself with brand new ones and had a look and they're hardly worn at all so idk if the bushes r as bad as they say they r cos i dont know WAT they r lol
take it to pedders liam,just $14 and make things are bit clearer.took mine,ended up knowing one of the guys,cost me nothing.then performance shop did a free check also.be polite,see how you go.full bush kits are available,do some research on here and net.good luck.
Edited by GT ARRRGH
I don't trust Pedders either. I took my car there for a wheel alignment and free 28 point safety check. They f**ked up the wheel alignment. And then told me my rear cradle bushes were shot and it was going to cost around $5k to fix because it is an import and they have to completely custom make a new cradle. Yehhhhhh no.
If you're in WA then it's WA Suspensions or bust. I took the car there straight after Pedders, the boys said there was a little bit of movement in the cradle but it really wasn't that bad, they replaced the bushes with pineapple bushes to tighten things up and fixed the wheel alignment. Cost me 500 bucks.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
