hi all, i recently put a rod threw the block of my 32 ive bought another rb20 and striped it down to replace the bearings and get the bottom end balance, im wanting to make around 225kw current mods are
fmic
25 turbo
electonic boost controler
3inch dump and full 3inch zorst
ive got 3grand to play with, id be happy to make 300hp with that cash, could u list the upgrades ile need please,
thanks =)
https://www.sau.com.au/forums/topic/361090-3g-to-spend-to-make-225kw-on-rb20/
The best bet dude would be to check the Rb20 dyno result thread at the top of this forced induction section.
in there all you need to do is go through the results, find the guys that have around the power that you want and see what they did/what mods they needed.
Probably the best way to get an idea.
yea i did go threw about 12 pages of it but its so mixed its hard too tell, some ppl are making 220kw with stock everything and more boost and some are only making the same with a forged engine 600cc injectors, computer, 044 pump, ect i was making 190kw with my mods already till it poped but that was due to me turning the skyline into a boat... long story haha..
thanks for the help though bro
Edited by 51NNA
As crazy as this sounds mate, what about this:
RB30 NA Block, Crank, rods and Pistons (Basically a running short block motor) - $50
New standard Size Hastings Rings - $120
New Standard Sized King Bearings all round - $140
Acid Bath, Hone, Deck Block - $300
Crank Collar and Fitting - $200
Head Gaskt ARP - with Fire Rings - $45
Cometic 3 layer Steel Exhaust Gasket (ebay) - $40
Tappet Cover Gaskets - $15
Front and Rear main seal $100
Cam Shaft Seals - $40
Loctite of Various sorts - $100
RB25 Head - $500
RB25 head recon - $600 (Deck, recut valves, Valve tip heights, weld VCT hole) ((I had 1 hour of porting done on the exhaust side, for $100. Made a huge difference)
Helicoils for Exhaust Side Studs $100
Autobarn Greddy Copy Chrome Intake Manifold - $350 (MUCH better than the ebay ones..!! Comes with all fittings and bolts)
Bolts of Various sorts - $50
RB20 ECU remap - $500
Total: $3250
I'd allocate $4,000 just in case.
How do I know? I did it the weeks between xmas 2010 and new year 2011. My car is running 100%. Had a few hicupps, but that was because I didn't get the head or block decked. Lucky for me, I only needed to get the head decked.
TIPS:
- You put it all together. Don't over pay some other flamin mongrel to do it. Surely you have a mate that is a mechanic. A real mate, not just some dude up the road you know of. Took me about 2 weeks to do a full assembly. Trust me, its not hard. Just make sure you find and engine that hasn't been trashed. Mine came from an old guy that crashed it. The VL had only done 140,000s and was like new. Still had hone marks. The hone I had done to it made it come up like new. Was about half a thou ovaled at the most.
- Use the standard NA pistons, and get CRC gasket stripper and spray the f**k out of them. The carbon will run off like water. Don't get this shit on your hands.
- GET THE HEAD RECONNED! You won't regret it. If you have a spare $100, get the exhaust ported. WIll do magic.
- Get a Standard RB25 exhaust manifold and port it! Don't go paying $5,000 to extrusion hone it. Get a die grinder, an old gasket, and port it. Clean the inside out. Lumps, thick areas, etc.
- Get GTR cams, or NA RB25 CAMs, and don't run VCT. Then you can do a cheap remap of your RB20 ECU, or get a Nistune Daughter board.
- Run the RB25 turbo and limit your revs to about 6,000. Trust me, you'll be smoking the tyres from 1200rpm all the way to 5,000rpm with that turbo.
- Save up for the next 6 months and get a GTX3076 turbo and enjoy 320rwkws with f**koads of torque.
There is your RB30 slapper that will take 300rwkw easier than a hooker being given 2 kgs of crack to give you a blow job.
Edited by The Mafia
Put the new RB20 in without rebuilding it.
Send your turbo to hypergear and tell him what sort of power you want, should cost about 1100 to do to whatever spec you want.
Get a Z32 for 300, get a nistune for 1200.
Get a fuel pump for 200
Get GTR injectors 2nd hand, no idea on the price but you should be safe.
You could even go for 250kw, shouldnt be a problem other than lag.
RB30 Block, Crank, rods and Pistons (Basically a running short block motor) - $50
RB25 Head - $500
Total: $2750
TIPS:
- You put it all together. Don't over pay some other flamin mongrel to do it. Surely you have a mate that is a mechanic. A real mate, not just some dude up the road you know of. Took me about 2 weeks to do a full assembly. Trust me, its not hard. Just make sure you find and engine that hasn't been trashed. Mine came from an old guy that crashed it. The VL had only done 140,000s and was like new. Still had hone marks. The hone I had done to it made it come up like new. Was about half a thou ovaled.
Thats all good, but what about the ancillary stuff?
AFM
Injectors
ECU
Tune
Fuel pump
etc
My recommendation:
Injectors
nistune
AFM
2nd hand turbo of some sort
Pushing it for $3k though
AFM
Injectors
ECU
Tune
Fuel pump
I'd run these standard until there is more money available.
Or -
AFM - Get a Q45 somewhere for $50
Injectors - HiFlow them to 600cc for $250
ECU - Already said and costed remap the RB20 one
Fuel Pump - Bosch 044 - $250
The 30 is a great idea, I did mine in a weekend.
With ancillaries, you stick with whatever suits the head and the car. In Mafias case, R33 RB25DET head is the better choice. For the OP, an R32 RB25DE head is the go (what I used).
With an R32 RB25DE head, everything is the same as RB20, it all swaps across. There is some minor modding of power steering bracket and exhaust manifold, then massaging cooler pipes but it's nowhere near as scary as some people make it out to be. I literally drove in on a Friday arvo and drove out about 1am Monday morning.
With an RB25 turbo @ 12psi, it made ~250rwhp @ 4600rpm.. 3000rpm 2nd gear launches ftw :D It seriously makes a 32gtst even more fun than they normally are, IMO it's how they should have come out of the factory :P
lol at recommending an rb30 for 300hp and 3k.....
he will need an rb25 box and decent clutch too thats at least 2k...
wack the rb20 back in with nistune, hks 2530 and supporting mods.
LOL @ you for not thinking with your brain.
He won't need an 25 box if his 30 is only running say 200-250kw. Just becasue you have the ability to run over 300kw doesn't mean you have to.
Keep it sane until the money allows and upgrade bits one by one until you have the strenght to whick it up some more.
The 30 makes way more sense than reco'ing a 20..
Its not the power that kills them its the savage torque.... I killed 3 rb20 boxes behind a 160kw rb20...
It will work yes, but its not fair to say you can do an rb30 build for 3k when theres a very high chance of a gearbox failure.
I would never reco an rb20 just get a good second hand one.
gtr injectors
walbro pump
z32 afm
hiflow internal gate turbo
nistune
electronic boost controller
im no expert, but by looking at the rb20 turbo upgrade thread, this seems to be a fairly cost effective way???
thanks for that info mafia but before i bought the 20 i looked at the hybrid build and thought it would cost too much, i might look at doing it again but i just love the way a rb20 revs, cant beat the sound of it reving to 8500 lol, im an apprentice mechanic so the build would be covered, my gearbox is on its way out, second gear syncro is grinding, so a box replacement will be done anyways
Apparently $350 is all you need to full balance a RB30 setup... (WOuld be the same as a RB20)
Rev it to 8k ;)
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
