Also fired up there Super sedan drag car, over 700 horses NA windsor V8 its evil, ran a best of 9.7. When we were talking i was like "pfft ill run ya, my skyline would kill it" lmao (hint at the highly sarcastic tone of voice :whistling: ) was a good day.
Little quite in here as of late. Anyway EOI at this stage, planning a cruise with the final destination being my place for a BBQ. Want to have at least 10 people before planning any further
yer im in man, can totally grab some snags or something to cook up :P
  • 1 month later...
hey lads good to see some more guys on here - we are planning a cruise in a couple of weeks time, pm Chris (o||oskylineo||o) for dets
Keen to see your GTR, Reece and Nathan i'm guessing you work at JB?
When did I get pointed cruise director? domokun.gif lol
Good to see you new Toowoomba guys are finding this thread and dropping us a line. Plan is to go on cruises every 2 or so months. And there will be a Toowoomba christmas/new years bash again this year after how well last years was, even when it pissed down rain
Hi guys,
Just recently upgraded from an S13 SR20 to my new R34 4 Door RB25DE skyline.
Trying to figure out why i didnt buy one earlier? lol
On my p's so no turbo :rant:
Suprised there was a toowoomba forum!
Hi guys,
I had the same problem. I was born 6 months too late and got stuck with the p plates. I almost brought an N/A but decided against it and saved for my GTR.
The amount of skylines in Toowoomba I was surprised there was nothing on here when I got mine
Yeh, I'd kill for a GTR but thinking of doing up the 34 cosmetically until my opens then just slapping a new turbo motor in it!
I work at butlers and we have 2 skyline owners, myself and then a black 2 door 32.
other than a couple of p plater 33's ive only seen a yellow 34 getting around, havent seen many of the others
there is a V35 owner up there somewhere. I keep getting calls about it.
Oh that's right i forgot about volkys,
He works at Signs on time, i went to school with him. He is a good mate of mine. Nice car
Ton of r33 p platers have shown up in recent times, Frankies is the yellow r34 N/A and then there is Aaron's white 34 coupe, (if he still has it) he has been on a few of our cruises but dropped off the radar. You work in spare parts at butler's? is Nic with the chaser still working there?
I used to see a blue one on my way to work. Haven't seen it in over a year
Give me a time and date mate and ill be there :cheers:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
