Hey guys. Going to be going for a cruise on Sunday. Just going to be a bit of a drive to a pub for a feed and a couple of drinks to catch up and to meet some of you new people on here. The last couple I have tryed to organize have fizzled out due to lack of numbers. If your interested just post up here if your keen then I'll pm you through the week with more details.
ok, so new natro motor and gbox are in... just gota wire it up and connect the drive shaft. then off to tbar to reclaim my throne as natro dipstick lol
dw, it has remained untouched. Think we are definitely due for a catch up
  • 3 weeks later...
Hey guy's, my name is Michael. I've just moved back to Toowoomba. Once a week I go and wash my car at carlovers. Also I just moved from living at the bottom of Mt Tamborine. I used to love going for a drive up the mountain and down through the hinterlands with other cars. If you guys can show me a good run, something similar, I'd be much alibied.
Hope to see you guys on the road. My car is easy to spot. Number plate is B FUN.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
