Think I've spotted this one a couple of times.
And....whats with Concannon field being the latest spot to sell your skyline?
Keep seeing 2 33s there for sale...both of which I've never seen in town prior to them being put there.
finally got her regoed this week. would have waved if i saw you, sorry
and yeah i work at the uni, see quite a few skylines in the paddock for sale.
cops were taking rego numbers, etc the other day
Edited by Nerfbatt
Hey everyone, i made a post in here several weeks/months ago talking about my parents moving to Toowoomba and i may possibly be following.
They have decided to move to Gatton, supposedly bogan capital of QLD.. just wondering what sort of work is there around Gatton/Toowoomba? Might add that i've been in new & used car sales for the last 2 years so i'd appreciate it if i could get a response on something relative to that.
cheers!
cheers!
Sean you're in luck, our good friend Nick666 is the mayor of the bogan paradise we know as Gatton. So much so that he is putting a V8 in his skyline to keep the bogan populace happy
There are quite a few car yards in Tbar so I would imagine you should be ok to find something? Just google
Hahaha Mackay is shit boring..
As mayor of the Gatton skyline club, I would like to point out Gatton is also boring and toowoomba is a much nicer place lol.
And sif put a v8 in to please the crowds, if anything id have to put in a natro dirty 30 for teh vl sceen or an ecotec lol... V8s take to much of the dole check to run fella :P
The oldies like the idea of moving there because of the "scenery" or some shit. And it's dirt cheap rent compared to this rip off town.
cheers!
Gatton is right up there, however I think Logan or even Ipswich would be the bogan capital.
Err parden,wot you talkin about. :wacko:
Don't listen to him, he is a drunken mess who doesn't know what he is on about
I could live with you putting a V6 Eco-tech in, easier to pretend it's a VQ38DETT, without the TT
Only reason why it's so dirt cheap is because you sleep on dirt in Gatton lol
I'd be there but I'm in Melb for Christmas visiting the folks.
How is the knee going? Also where are these pictures of my car from the charity cruise that you took?
Hey bro, how does one join the Gatton club? i assume I would be the only skyline in Laidley (someone correct me if I'm wrong), so I'd rather go to Gatton and meet with other skyline owners than get stared at like some kind of freak haha
The mayor of gatton just joins all of the cool kids in toowoomba.
Grave digger.... ^^^ this
As far as I know in Gatton there is:
A black natro 33
A Grey auto natro 33
A lime green 33
A grey 32 natro
A grey 32 gtr on lensos
A white 33 gtr
An orange 33 witch hecktic chromies
And a fark load of 31s
Oh and of course my LS1kyline which is unmissable
A black natro 33
A lime green 33
A grey 32 natro
A white 33 gtr
Pretty sure there is a white 34 GTR with LMGT's on it getting around Gatton also.
And isn't your 33 in Toowoomba at the moment with all the cool kids?
So far for the Christmas party we have
Me
Clint(sonnyQ)
Tom(Tommis85}
Nick(CaptinNatro)
Humbla(Coming from NSW)
Tony350?(If coming needs to wear a bra)
Me_larr are you coming?
Anyone else?
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
