So how many of ya's are actually going to that happy laps?
I'm still undecided....will probs just pay on the day if I go.
Ill be there in the skevy, will be its last outing as a two speed until my he box gets pulled... Depending on Chris's enthusiasm (as I haven't even asked him yet) I may be rocking some new BC's ;)
Well he never comes to lakeside :P that is nice and dangerous.
I have done lakeside happylaps a few time. Even before they put the cones around the back of the track to slow you down
Righto fitting coilovers to the abomination on Friday night at my place at around 5. Come around if you giys want for beers and bullshit while I fit them. Might even do a feed as well
Goes without saying but, I'm in :)
Will be supplying coronas for Chris and as I believe dalton is driving a six pack for myself, give us a text if you want some snags or anything brought up
In case you boys haven't seen the post http://www.skylinesaustralia.com/forums/topic/423450-an-evening-with-jim-richards-and-fred-gibson-18th-july/
Get onto this. Will be a great night and a great opportunity to meet the mastermind behind the R32 coming to race in Australia, and one of the drivers of these great cars. This is a rare and awesome opportunity to meet both Jim Richards and Fred Gibson. Get on this guys. I have already got the 18th and 19th off work for this and hopefully you guys will make it down also
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
