just wow. literally not one person got the eels out of my tipping comp
I was around at a mates place drinking and watching the game. One of my other mates who was there is a broncos fan. Its safe to say in my drunken state, I gave him that much sh*t about it that its started to no longer be fun. BUt hey I haven't had much to crow about the past couple of seasons
Those wtf plates?
Yep yep, "WTF*033" ;)
Also just sent some emails to get my box rebuilt to Handel some more grunt and a bigger stall to suit the f**k off cam I want to get
Should be lumpier than a Russian sleeping hostels mattress :P
Do you also plan on purchasing an oil refinery?
Wayd u do Scott!!!
Sif I can remember back that far...
*Handle*
Those wtf plates?
WTF indeed.
Oh hai Scott. Do you have a second SAU shirt for me in your box by any chance?
Hey Chris, I gave Nick 2 shirts with your name on it, but I will check for you.
any teeth left in this thread?
No teeth, no public health care...
Women in T-Bar don't have any teeth Phil, if you where aussie you would know this :P
Nor do they have velcro gloves.
Righto thanks Scott. No teeth = no chance of the girl biting off you cawk when getting a gobby off them
Should have been 4 shirts mate.
Also, can you bring Mike James' to the cruise? Or I can grab them from you prior if more convenient.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
