Hi guy's can anyone say what is a sensible knock value to tune to on a stock RB30 bottom end with Rb26 head using an Apexi ECU. IIRC the Apexi triggers the warning at 40 as standard. If you are reaching mid to high 30's under load often will this kill the bottom end or is it still relatively safe? I know my old RB26 reach 40's after it was tuned and I think they reset the knock warning to much higher.
Cheers
Lee
https://www.sau.com.au/forums/topic/361263-safe-knock-on-a-stock-rb30/
60 is the standard flash engine light value.
i use 60 as a general limit. my motor died after leaning out and pinging (around 200 on a pfc), but that was running 25psi boost at over 300rwkw on a 100% stock bottom end, i would never reccomend it if you want it to be reliable :whistling:
200! I didn't even realise you could get readings that high! I checked and my ECU is set to go at 40.. I just like to know these things for piece of mind. I know everyone says knock is bad but I never really know ow much is normal and how much is bad!
What rpm were you running your stock bottom end too out of curiosity? Was it a self built motor?
I've never seen more than 30-35 on mine. Only time i do is it i tap the limiter or something which obviously upsets things.
Otherwise i'd be around 20-30 just putting around.
40-60 would mean a wayward cell or two somewhere. Nothing major and not going to break stuff instantly but attention is required.
Thanks guy's for the replies. It puts my mind at rest. I would say it is generally around 30-35 and every now and then I might get a high 30.. just hit the 40 once! Will have a look into it.. Main reason I started asking is I just found I have a compression issue on one cylinder and I am trying to figure why! It's only done 900miles, been run in gently and just had a tune to 0.8 bar and only been revved to just over 6k! I am hoping it is a duff valve but it sucked/blew some oil through the breather into the turbo inlet so its not looking promising.
Cheers
Lee
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
