Hey every one im sure theres been a thread on his about oil change and what oil change to use... im just starting this thread as ive heard you need different oil depending on the cars modifications.
Its a r34 GT-T neo, ive got a FMIC, pod, 3.5 inch catch back, air flow controler, boost controler. What oil and what oil flter should I use? and where can i get it? supercheap? auto one? etc... thanks or the help guys.
Triston.
https://www.sau.com.au/forums/topic/361386-what-oil-to-use/
Nulon 10 40,been useing it for yonks no probs and no lifter noise,have done over 100000 klms using this oil,changed every 5000 and oil filter as well.Other's say it's crap but my 25 loves it.Tried the motul and had ticky lifters ,this oil really works well in my mildy modded rb25 am sticking with it. :worship:
https://www.sau.com.au/forums/topic/361386-what-oil-to-use/#findComment-5771694
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
