Up for sale is my project car i have been working on for 3 years, standard Blue in colour i have listed below current parts / modifications etc, interested in stripping for the right price whole car goes for $5,500
RB 25 DET done 55,000 (out of a r34) wiring loom and ECU
Manual gear box
Excedy 3 plate button clutch (on or off)
lowered suspension
new front mount
Z32 AFM
stainless steel cat back exhaust
series 2 dash and cluster
retrimed Blue and white interiour (excluding Driver seat)
* Roof
* Rear Seats
* Passanger Seat
* Door Trims
Fluted Bonnet
After Market Fuel Pump
Pod Filter
=Much more that has slipped my mind=
I will update with some pictures soon but if anyone is keen please e-mail me
[email protected]
0405 124 906
Edited by Ranga!!
https://www.sau.com.au/forums/topic/361430-r33-unfinished-project/
  • 4 weeks later...
Guys
i will get some pictures up tonight, also please note that i intend to sell this as a running car- unfinished project, this of course is negotiable and if you want to make any offers please call me, it is a complete car at the moment just needs a paint job and ready for rego.
0405 124 906
Trevor
Edited by Ranga!!
Please keep in mind it is ready for primer and I intend to paint within two weeks, once painted I will be very reluctant to negotiate price, all dints scratched etc have been repaired.
post-76886-0-97376700-1305672740_thumb.jpgpost-76886-0-49039200-1305673010_thumb.jpgpost-76886-0-66745500-1305673054_thumb.jpgpost-76886-0-61111400-1305673109_thumb.jpgpost-76886-0-39261300-1305673130_thumb.jpgpost-76886-0-62120700-1305673161_thumb.jpg
Interested in the radiator, suspension(if after market) and the A pillar with gauges. Inbox me if you're going to separate. Need a thicker core radiator to install when my belt goes on and that looks thicker than stock. Do you know brand or specs?
Also interesting to see the passenger side air bag in a series 1.1.5 didn't have the air bag, did it?
Edited by SargeRX8
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
