Wtb: R33 Gtst Power Window Switches & Mechanism
I have a spare mechanism from when I fixed mine, but it can take hardly any weight and would need to be pulled apart to see if the stupid little plastic gears are okay. I ended up pulling the motor apart and fixing my existing one after finding the one I bought online was weak as all sh*t. I'll pull it apart tomorrow and see if I can fix it if I get time :) if I can you can have it for free, nice to empty the spare room a bit...
The actual switch is generally a burnt out solder isn't it? If it's series 2 then generally the relay dies, and series 1/1.5 the board in the switch itself (because there is no relay) burns out. Look for cracks and little black marks :)
cheers bud let me know if its ok or i can do it myself, ill have another look at the switches tomorrow :)
Pulled it out of the cupboard and pulled the whole thing to pieces, there were some half eaten cog pieces laying around near the worm gear which may have been causing some issues. When I pulled the shell off the motor itself though it smelt burnt and looked a little black, when I last tested it everything worked but just not well, so hopefully it's still all good. Come around and grab it, if it doesn't work just shove it on the tip :) I did the install 3 times (what you get for not testing the strength before starting, then turning the magnetic casing upside down on my current one which made it all in reverse) so if you need a hand or you're having particular trouble with any part give me a yell.
Where abouts are you located? I'm down in Kingston and can make short trips around the place atm (currently soaking up some of my 3 months time in lieu) so let me know.
Jay
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
