Hi just curious what sort of values you guys are getting with aftermarket water temperature gauges, just fitted mine and there is a huge variance compared to the factory sensor/power fc. Could you let me know
1.what gauge have you fitted
2.where is the sensor located
3.what temperature range it reaches normal driving
Cheers
Pat
What car would you like these results from?
I have a Race Tech Water Temp Gauge and sensor in my modified RB30 an cruising on a cool/cold tasi day i'll see temps between 60-70 degrees and on a hot day as high as 80 degrees whilst driving aloing. The highest it's ever been is about 85 in traffic on a hot day. The sensor is located in the standard position. Hope this helps.
And how do you know there is a varience between the factory and aftermarket? As far as i know most factory gauges don't have exact points only a scale from cold to hot.
Kurt.
There are two factory sensors one is for the actual factory gauge in the dash which pretty much has a cold medium and hot. The one I'm referring to is the one connecting to the ecu. My aftermarket sensor is sitting in the upper radiator pipe and is reading a lot hotter which doesn't make sense.
1) AutoGauge stepper motor one
2) Top radiator hose
3) Ranges I've seen from 72 deg C to 95 deg C depending on outside temperature (had a couple of 40+ deg C days), how much air flow radiator is getting (ie not getting stuck in traffic or behind some snail in a Getz driving <40km/h) & weather I'm using A/C or not (I found that using it tend to increase the temperature while the car is idling/stationary by up to 5 deg C).
EDIT: Also I'm using the stock cooling gear, the radiator has recently being cleaned (& reported to have 0% blockage) & had the top plastic tank & seal replaced.
Edited by Mayuri Krab
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
