I have a 98 r34 gtt, 3"turbo back, FMIC, boost controller running 12psi.
while doing the 100k service, i took out its denso iridium IK20 plugs with a gap of 1.1
and replaced them with NGK bcpr6es gapped to .8
Now it misses at idle and a little when accelerating lightly up to 2000rmp, but is fine when driving normally and when hammering it.
I played around with the gapping and the smaller ther gap the worse it is, but even at 1.2, the miss at idle remains.
Its not running lean, ive checked coils, airflow meter and for any vacuum leaks, all that aside,
the miss dissapears when i put the iridiums back in....
Im stumped, my mechanic is stumped...
I know i could just run the iridiums, but there must be something causing this, and its driving me nuts....
Could it be injectors?
Any help please??
https://www.sau.com.au/forums/topic/361819-new-spark-plugs-missfire/
put the old plugs back in. if the miss goes away then you no it's am issue with the plugs. if the issue stays then i think you will find that the issue is with the coils. may have been a bit dodgy before hand and in the process of changing the plugs the got damaged and now they are worse.
Sounds like my issue i have just changed my injectors..
Sounds like its on 5 cylinders if you gently rev it..
yes thats what mine sounds like, did the injectors help?
just buy the stock plugs n gap them too .7 or.8, cheap as fu*k and will probs fix your problem n near last as long as iridium plugs- i think they are
BCPR6ES-11
tried that, didnt help
tried that, different only iridiums make it go away, also swapped my coils witha new set to test, made no difference
Maybe you dislodged some crud and it dropped into one cylinder?
blew it all out with compressor before i removed plugs, and it goes away with iridium plugs
thanks though eveyone.... :s
Is ur ecu tunable? Some skylines do this. Its like an intermittant lean pop at idle?
If it annoys u just richen up the idle a tiny bit or keep running the iridiums if thats what ur car likes.
as far as i am aware its still the standard ecu as it has the sticker/seal on it.
im the first oz owner too, i think they have to make sure the ecu is standard when going through compliance... unfortunately lol
and yes it sounds like a lean pop, but my tuner put it on the dyno and its still rich, runs safe allthrough the rev range with a smooth power curve.
im ok with running iridiums... but still i really wanna know why its doing this.. is this common at all?
Edited by camoo
Alot of skylines have lean pop at idle intermittantly.
I normally richen the idle until the popping stops.
Why it happens with certain plugs i honestly cant answer that.
hmmm driving through the city today i can notice it while going slow.... very annoying....
and its already running rich...
ill put iridiums back in and see how it runs...
any more ideas though?
did you drop one of the plugs when fitting them? they are fragile things and can get damaged easily...
but yeah throw your old ones in, even if its one by one and see if the missfire at idle goes away.
na didnt drop any,and even then, i went and bout another set of the NGKs just to be sure.
Also tired replacing plugs 1 at a time, and untill its all iridium, it still misses....
cheers though..
so im going to try the o2 sensor in the exhaust....
Not to sure if this will have to much of an affect but with my limited knowlede i believe this is a logical step...
Any one agree or not?
help???? lol
NOTHING TO DO WITH THE O2 SENSOR!!!!!!
Standard Iridium plug is a (NGK) heat range 5, I believe. Try some BCPR5ES plugs, see what happens.
yeh is did nothing tring another o2 sensor, so good call...
i got some ngk iridiums to put in tomorrow, just annoying that everine else with this same angine and same mods can run standard copper plugs, yet mine wont...
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
